Silverstar Bulbs
just bought the silverstar ultras like 3 days ago. i was disappointed when i turned them on in the daylight because they didnt look a WHOLE lot different. then it got dark out and my opinion changed. they are noticeably whiter, and unlike some cheaper bulbs i have run before the light output is actually damn good. it does seem they are brighter and project light further. good enough review?
on another note, its always kinda bothered me about the headlight bulbs being much yellower than the fogs, and now they are the same whiteness
meh, the ultras are brighter
Last edited by hatrickstu; Dec 23, 2007 at 08:58 PM. Reason: Automerged Doublepost
ya that helped that would be nice if there the same whiteness as the fogs i hate how there different. ill be getting projectors later on with hid but fiugred it would help for the next few months till i get the money for em i needa mod the car a lot more before i get the projectors.
takes about 15 minutes or so, i had to pull the headlight assembly out, but if you have tiny hands you could do it without pulling them. its pretty easy to get out the headlights, just watch the paint on your front bumper
Just like mostly everybody else said, they are a little bit whiter and quite a bit brighter. I think that they actually seemed a little bit whiter after I painted my headlights black. BTW the Silverstar Signal bulbs w/ the amber lens removed looks soooooo hot.
http://www.sylvania.com/ConsumerProd...al/default.htm
Unlit:
Lit:
Unlit:
Lit:
I have Silverstars...the only problem is that a headlight bulb will buirn out every few months or so.........I've replaced my driverside bulb once since having them, and jusr had to replace my passenger side last week.......and I've had them for about 6 months.....so htey will burn out but they're not too expenisve to replace so I wouldn't worry and they look great
Yea it looks pretty sick. I noticed that you have an '06, so to get the true effect you would need to open up the lights and remove the amber lens, otherwise it would be a waste (you would still see amber when the bulb is off). Check out https://www.cobaltss.net/forums/how-guide-43/how-paint-your-headlights-lots-pics-56k-mabye-16874/ if you aren't sure what I'm talking about.
[QUOTE=kkanowitz;1788179]Just like mostly everybody else said, they are a little bit whiter and quite a bit brighter. I think that they actually seemed a little bit whiter after I painted my headlights black. BTW the Silverstar Signal bulbs w/ the amber lens removed looks soooooo hot.
X2.... this is definatley the way to go... IMO i would also get rid of the orange side marker and clear it tho... looks bad ass
I put Silverstars in my projectors about a month or 2 ago. Both are already burned out......I'm very disappointed with them. Color wasn't much different, and they weren't brighter than stock. Waste of money IMO.
