SS 18" wheel weight?
Does anybody happen to know what the stock Cobalt SS 18" wheels weigh? I'm just wondering how much performance there is to be gained by going with some light-wieght 17's. I'm thinking Kosei K1 Racing or SSR Comps (expensive!) in a 17x7.5, and some good 225 rubber. I don't have an SS yet... just speculating. IMHO the 18" rims and the huge wing should be optional.
you seriously think your going to save a lot going to 17's over 18's? :rolleyes:
Actually, yes... There is MUCH to be gained if you can SIGNIFICANTLY reduce the weight of the tire/wheel combination... good luck!
The only problem is I don't think either of the two aforementioned wheels come in the right bolt pattern. |
how much heavier is the tire going to be though? I am sure you can find ligher wheels then the stock ones yes, but I think going down in rim size isn't going to save as much as staying the same size, because to keep the same overall tire diamater, you will have to run tires with taller sidewalls on the 17's, which is going to add more weight at the worst spot, the farthest out. I think you would see the biggest gain going with lightweight 18's.
how much do the new 18's weigh?
looks like the msr 045's weigh 21-22lbs, and i wanna know if they are lighter or heavier than stock |
my appologies. i responded to the wrong thread...
stock wheels weigh 20.5lbs and msrs weigh 22-25lbs ftr... |
per this thread....https://www.cobaltss.net/forums/whee...-read-me-8149/
the answer is....edit 6: The stock wheels weigh 24 Lbs. (courtesy Chevypowered) |
