ss body kit
Old Aug 18, 2009 | 10:48 AM
ace6904's Avatar
ss body kit
i have a ss body kit for my ls, i know how to put the front part on. I want to know how should i do the rear lip and side skirts.
its a ls sedan.
Old Aug 18, 2009 | 10:51 AM
umrdyldo's Avatar
There is a How-To on the rear lip.
Not sure about the sides.
silver187666's Avatar
ill doit for you, bring it over
Old Aug 18, 2009 | 11:25 AM
jschatte's Avatar
look at the how to guides. That should help you out with the front bumper and rear lip. If you think that rear lip is gonna fit on your ls bumper, you are sadly mistaken as the lip needs to be shortened to fit. Beleive me i did it lol. As for the side skirts you have to drill 8 holes on each of your rocker panels, the best way to do this is to use the sideskirt as a template.
Good Luck, andd as i mentioned use the how tos!
Old Aug 18, 2009 | 11:28 AM
dayhoff35's Avatar
i was wondering this to but are the holes marked for the skirts?
Old Aug 18, 2009 | 11:34 AM
jschatte's Avatar
there are 14 clips on the sideskirts. 6 of them are on the bottom of the car, parallel to the ground, these are already drilled. The 8 you need to drill are on the visable part of the rocker panel, about an inch below the door. these holes are not marked. I clipped the sideskirt in the bottom holes and figured out from there where the top ones should be, then drilled them out. Some people have used 2 sided tape instead of drilling the holes, but this way is SOOOO much more sturdier. Dont want those skirts coming loose on the highway or something.
Old Aug 18, 2009 | 11:36 AM
dayhoff35's Avatar
yeah i will probaby drill them but i havent gotten them yet so i guess ill finds out what your talking about when i do get them but yeah i saw oa skirt duck taped on a grand prix going down the highway lets just say all of it didnt make it home
Old Aug 18, 2009 | 01:22 PM
Icydub's Avatar
For the rear lip you have to cut your own holes for the clips, im not sure if it would work on a ls bumper though
Old Aug 18, 2009 | 01:35 PM
ace6904's Avatar
will the coupe side skirts fit my sedan?
Old Aug 18, 2009 | 01:37 PM
mkulrey13's Avatar
Yes, use adhesive silcone or w/e its called. used it on my sedan and it lasted 3 years before i pried it off to sell it haha.
Old Aug 18, 2009 | 02:43 PM
dayhoff35's Avatar
will the silicone leave any resadue or peal off the paint?
Old Aug 18, 2009 | 08:43 PM
jschatte's Avatar
it wont fit properly, it requires some shortening.
Old Aug 18, 2009 | 08:56 PM
jonxxxedge1's Avatar
where did u buy the bodykit?
Old Aug 18, 2009 | 09:58 PM
Icydub's Avatar
Thats easier The harder part is probably marking and cutting everything
Old Aug 19, 2009 | 01:26 PM
ace6904's Avatar
i got it from dealer
Old Aug 19, 2009 | 01:31 PM
slobalt08's Avatar
Side skirts fit on both coupe and sedan
Old Aug 20, 2009 | 01:17 PM
jschatte's Avatar
no, its pretty difficult, it requires a section to be cutout of both sides, then the lip plastic welded together. I had to get a body shop to do this. However it is still a pita cutting all the slots.
dennis69
Oct 20, 2015 04:49 PM
SSLOW06
Oct 1, 2015 07:21 PM
yellow dragon
Sep 28, 2015 09:49 PM
Sep 28, 2015 12:51 PM
