SS foglamps
Old Sep 25, 2007 | 12:12 AM
joeworkstoohard's Avatar
SS foglamps
okay, how do i get to the bulbs in these freaking foglamps?
Old Sep 25, 2007 | 12:50 AM
Renesis's Avatar
you take the headlight out and then reach to the bottom, turn it and you're done.
on my 2.4 some kind of intake thing was blocking access on the passenger side so I had to go from the wheel well, it was more trouble.
there's a how to already:
Tools Needed: 10mm socket, ratchet, extension (To make it easier), flat head screw driver & Bulbs[/list]
Ease of Install: Easy - once you get the headlights out it's smooth sailing.
Estimated Time to Install: 15-20 mins (depends on how long it takes you to get your headlights out).
1) Remove the two 10mm bolts holding the headlight in and also the push clip holding the top of the bumper to the grill. (Very faint green circles)
2) Grab the side nearest to the fender and wiggle out the headlight, if needed pull up the grill or pull the top of the front bumper out to get the headlight out. You can also remove the clips that hold the front fascia on to help you wiggle the light out.
3) The fog light is then visible down under, as seen in the picture, twist the bulb from the fog light and bring it up to take it off the wire.
4) Open the 2 clips on either side of the light
5) Then put everything back together doing the above steps in the reverse order.
Joe Schulte
Mar 1, 2014 02:39 PM
CARLYLE
May 20, 2008 02:36 PM
TWIZTED 2.2
Sep 3, 2006 12:15 AM
roccobladr
Jul 30, 2006 02:21 PM
Cobalt30
Dec 30, 2005 09:06 PM
