ss/tc grill
there not hard at all. remove the top clips than pull the grille out a little. than there is 2 square bit screws you have to remove you have to look down. one is on the left and the other is on the right.. dont use a phillips head because you will strip it. after you get the 2 screws out pull the grill out. put the new one in and put the screws in than put the clips in and your done
real simple just dont use a phillips head
