Suspension!
Old Oct 17, 2007 | 06:08 PM
SShocker's Avatar
Suspension!
which suspension comes in a 2.4 cobalt. is it the same as teh 2.0 or 2.2. springs and struts. i dont think its the 2.2 cuz it has front and rear disc brakes but it seems diff than a 2.0. can ayone help me out
Old Oct 17, 2007 | 06:09 PM
XM15's Avatar
The 2.4 and the 2.0 share the same suspension.
Old Oct 17, 2007 | 06:12 PM
Herndon_High_SS's Avatar
Sorry sir you are incorrect. The Fe3 is the suspension that is on the Cobalt SS and the Fe5 is on the Cobalt SS/SC. Here are the differences-
• FE3 suspension – standard and available only on SS models, it delivers a firmer, more direct ride and includes 22-mm front and rear stabilizer bars, four-wheel disc brakes, monotube shocks and 17-inch wheels and performance tires
• FE5 suspension – standard on the SS Supercharged, it was developed on the racetrack to deliver sports car levels of handling and grip; 24-mm front stabilizer bar and 22-mm rear stabilizer bar, higher-rate springs and bushings, four-wheel disc brakes, monotube shocks and 18-inch forged aluminum wheels with complementing performance tires.
Straight off of www.crateenginedepot.com
http://www.crateenginedepot.com/stor...s-W62C188.aspx
Old Oct 17, 2007 | 09:13 PM
SShocker's Avatar
wow nice info...thank god u know ur stuff. are the springs the same or not
Old Oct 17, 2007 | 09:42 PM
No the springs on the SS/SC are a higher-rate spring. Also as you can tell the SS is not as low as the the SS/SC. For example-
Cobalt SS
Cobalt SS/SC
Old Oct 17, 2007 | 10:11 PM
SShocker's Avatar
yeah i wanted to make sure because all the companies that make springs out there dont know how to rate the cobalt...they rate the ss and the ls.....they dont describe in detail for each car. i wanted to lower my car but not so much i would be bottoming out. thank you very much for your info and it helped me a lot!!
Old Oct 17, 2007 | 10:18 PM
Anytime. Glad to help a fellow member.
Old Oct 17, 2007 | 10:21 PM
SShocker's Avatar
you did more than help haha!
Old Oct 17, 2007 | 10:23 PM
jigyflyuk07's Avatar
Try all the vendors on here. Most are just for cobalts so you can't go wrong with them.
Old Oct 17, 2007 | 10:24 PM
SShocker's Avatar
btw....what does a stock cobalt s/c have in hp to the wheels and then with a stage 2??
Old Oct 17, 2007 | 10:29 PM
XM15's Avatar
There is a pretty fair range of what you could be putting to the wheels. Probably somewhere in the range of 205-225 or so. Stage II could take you ~240whp or so.
Old Oct 17, 2007 | 10:31 PM
SKCobalt's Avatar
To my understanding.... you should be getting pretty close to 240 hp to the wheels with stage 2. Depends on what dyno you use though.
Old Oct 17, 2007 | 10:32 PM
XM15's Avatar
I stand corrected. I didn't see that he was talking about the entire suspension setup. They are the same springs though.
Old Oct 17, 2007 | 10:36 PM
I dont think they are.
Old Oct 17, 2007 | 10:38 PM
XM15's Avatar
Everything I have read on here says that they are. I believe Jackalope had looked up the part #'s and they were exactly the same. IDK
Old Oct 17, 2007 | 10:39 PM
It's possible. But from what I have seen they are not. But of course I may be incorrect. Let me dig around.
Old Oct 18, 2007 | 11:02 PM
^^why would it be impossible?
Old Oct 18, 2007 | 11:09 PM
I never said it was impossible. It seems unlikely though because if you stand side by side the 2.4 and 2.0 stock suspension makes the 2.0 look lower. With or without the bodykit.
Thank you.
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
