Tail light out! HELP!
Old Jul 28, 2010 | 10:17 AM
Brenden Griswold's Avatar
So I got pulled over the other night for having a tail light out....the only issue I have is the fact that last week I replaced the bulb in the tail light. Everything's hooked up and the bulb is brand new. But for some reason that one tail light will not freakin turn on! Any trouble shooting ideas?
Old Jul 28, 2010 | 10:21 AM
ADIDASS's Avatar
Does the blinker work or freeze? Do the 4-way's work? <-- For this side/bulb Does it not work at all?
Make sure all the connections are solid. Check the wires for pinched, cut lines...
BLAZIN07SS's Avatar
I'm too JDM for you
make sure it is getting power. could have been a bad bulb you bought or you touched the glass and got oil on it so it burned out
Old Jul 28, 2010 | 10:42 AM
The blinkers dont work, it seems like there's no power going to it. I checked fuses, and the bulb was fine.
Old Jul 28, 2010 | 11:36 AM
ADIDASS's Avatar
Do you have a tester? Just to see if the wires coming up are hot... Ground it and test each wire. If you aren't getting any power, you have a short somewhere in the line...
Old Jul 28, 2010 | 01:53 PM
scottie's Avatar
It doesn't matter if you touch the glass on a tail light. Its glass, not halogen. Its not going to be a fuse either if only one side is causing you problems. Do ad ADIDASS suggested and test for power. Could be connector or wiring.
How does the connector look? Any corrosion on the points of contact?
Old Jul 28, 2010 | 02:12 PM
iboost's Avatar
I'm not 100% sure on this so don't quote me...but I think turn signals and 4-ways (Hazard Lights) are different relays. So just because a turn signal doesn't work...doesn't mean 4 ways wont. I might be misunderstanding what you are saying, but I have the electrical schematics right here for cobalts.
Old Jul 29, 2010 | 11:44 AM
hahahahahaha i give everyone permission to laugh in my face...
I took the light off and got to the bulb and discovered the bulb was never pushed fully into it's socket. . . Magically it works now!
On another note, there is a tiny little bulb in the corner of 4dr tail lights thats blown out, but im not sure what it does. Can anyone tell me what its used for?
Old Jul 29, 2010 | 02:00 PM
DaBuzzard's Avatar
That would be your reverse light.
Old Jul 29, 2010 | 02:31 PM
wantedSS/TC's Avatar
Old Jul 29, 2010 | 02:59 PM
@nt1ric3-420$$'s Avatar
Glad it was that simple...future reference check the bulb filament first then fuse if it went out hope the bulb wire burning shorted the circuit and blewthe fuse. If the fuse is ok then check the socket for power Otherwise u/have alot/morework trying to find short along the circuit. A pinched or broken wire either from the factory or fr aftermarketr installations
Old Jul 30, 2010 | 08:48 AM
not that bulb. Its in the outside corner, its super tiny
Last edited by Brenden Griswold; Jul 30, 2010 at 08:48 AM. Reason: Automerged Doublepost
Old Jul 30, 2010 | 08:57 AM
It's a side illumination bulb in the taillight for if your main bulb goes out, this one still keeps the light illuminated a little bit.
should be a 194 bulb.
Old Jul 30, 2010 | 12:22 PM
DaBuzzard's Avatar
^^^ doh, didn't think of that one. Forgot the sedans don't have the seperate side marker
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
