tails on sedan help
Old Apr 27, 2009 | 11:05 AM
SteveORyan's Avatar
tails on sedan help
Well im gnna do my tail tint soon and i want to know the best way to leave the reverse part the same
Old Apr 27, 2009 | 11:26 AM
SSfamilywagon's Avatar
After you do a light inital sanding to get them prepped, tape off just the reverse lights. You good tape and a razor blade to cut the circle out. Thats how I did mine. i was just very careful. Then after you spray all your tint on and your ready to clear, remove the tape to clear the whole housing. Remember alot of light coats is better then 2 heavy coats.
Old Apr 27, 2009 | 11:38 AM
SedanMan08's Avatar
Just Tint the whole taillight, IMO it looks alot better and you dont have to worry about tape messing up your tint job. My sedans taillights are completely black and the reverse lights are still very noticeable when backing out and such.
Old Apr 27, 2009 | 11:50 AM
SteveORyan's Avatar
awesome i got vht spray im only gnna use lil coats, you got a # man
Old Apr 27, 2009 | 01:21 PM
liljone's Avatar
you just tape off the reverse light with painter tape. If you are smoking your lights you will be able to still see when backing up but if you going full black I would taped them off.
p.s. don't forget you need 600 grit sandpaper.
2x
I smoked mine and can see fine when I back up:
maliki778
Oct 1, 2015 07:39 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Cptnslo
23
Sep 15, 2015 10:53 PM
royce777
Sep 14, 2015 12:17 PM
