What can I do?
Old Mar 30, 2008 | 10:28 AM
06BrandonSS's Avatar
What can I do?
Whats up guys? Ok so a few weeks ago I pulled my headlights apart and painted the inside. When I went put it back together, some glue got onto the plastic outer lense of the light, so I tried to get it off before I put it back together. Nothing worked at all, it just smeared it. I tried paint thinner, gasoline, WD-40, everything, nothing would get it off. So I just had the intention of buying a new headlight and redoing it. Well needless to say I kind of slacked off on getting a new headlight, and now the Midwest Meet is next week and Ive got a shitty looking headlight. So what I was thinking is pulling it back apart, and maybe taking a real fine grit sandpaper and wetsanding where the glue is, will that work? Any other ideas? Thanks!
Old Mar 30, 2008 | 11:03 AM
Black07LS's Avatar
Try Goo Gone or bug and tar remover.
Old Mar 30, 2008 | 11:05 AM
Lol tried
Old Mar 30, 2008 | 11:17 AM
REIGN SS's Avatar
Original Hayden Fanatic
heat and a razor blade?
Old Mar 30, 2008 | 12:04 PM
brandon2.2's Avatar
let it soak on goo gone for a while, like an hour, and then do the above ^ use a heat gun (hair dryer should work) and a razor blade.
if that doesnt work, BEFORE you try using sand paper I would try a wax rubbing combound that has pretty heavy grit to it (the stuff you would use to remove scratches in your paint)
get your rag wet and the lense wet and dont forget to buy some elbow grease.
Old Mar 30, 2008 | 02:52 PM
Sound good guys, Ill definitely retry the goo gone. I cannot try the razor blade because its not thick enough, it had little viscosity to it when it melted. Thanks for the help!
Old Mar 30, 2008 | 02:54 PM
Mnatvyc1223's Avatar
try some peanut butter! lol
Old Mar 30, 2008 | 04:32 PM
kenstacy125's Avatar
lol
Yeah try a heatgun and a razor that sounds like the best bet.
Old Mar 30, 2008 | 07:06 PM
I wonder why I didn't think of that myself, thanks! lol
Ill mess with it this week and hopefully get this crap off, thanks!
