Whats the possibilty
if u paint a valve cover with the gm paint and then clear it with the high heat clearcoat will it peel?
im thinking yes it will but does anyone know for sure?
I did this on my truck... it was fine... just clean the **** out of it first. i scuffed mine up with a wire brush too. that made a difference i think. There's also engine block high heat enamel paint that comes in Chevy racing colors too.... just a thought...
i'm not sure. I've helped and done myself primering and painting of intake piping, spark plug covers, superchargers and havent had any issues.
I have done some of the same with out primering, and just the gm paint with clearcoat and they have flaked.
i would say no. the plastic doesnt get as hot as the rest of the engine because its plastic obviously. the high temp clear coat will hold the whatever is underneath it in. make sure you fine sand and primer it first
not with the GM paint, but with normal dupli-color gloss black.
I dont want to promise you that it won't flake, because i'll feel shitty if you do it and it flakes after a while. From my past expierences i have seen that if you put a few coats of primer down, it usually helps, but i cant guarentee anything
James_SS
Aug 26, 2020 08:48 AM
