Autocross and Road Racing Road racing is not “street racing”
Autocross Setup
Old Jun 1, 2008 | 08:52 PM
Tracer 06's Avatar
Autocross Setup
What are the different setups you are using for setup? Air pressure front and rear? Wheel and tire size? Lowered.... how much? Camber front and rear? Toe front and rear. Thanks to everyone that answers. I drive a 2006 Cobalt SS Supercharged.
Old Jun 7, 2008 | 07:06 PM
SoloZ/SS's Avatar
There are different thoughts on rear pressure for FWD car and which is best, I have been recently trying 42 or so psi in front and about 30 or less in the rear. I use Toyo RA-1 235/40r17's but I am thinking I would like a wider set all around but haven't too much thought into it. I am also running on Sportline spring but am going to trade someone for there Prokit springs and hoping it works better. I did the sloting of the knuckle mounts on the front struts to get -1.7 * of camber, can't remember the toe. The rears you can't really do much unless you get shims. Seat time seat time seat time is the best thing you can do for your car.
Old Jun 7, 2008 | 09:31 PM
suburbanrobot's Avatar
I run similar tire pressure, 40 front and 32 rear on the stock Pirelli's (almost like slicks now). Otherwise, I am just running the stock suspension and an Ingalls torque dampener (check to make sure this is legal in the class/organization you run with).
Last month was my 1st Auto-X after a 16 month hiatus.
Auto-Xing is tough w/o the G85 pkg.
Seat time is king!
Old Jun 7, 2008 | 11:49 PM
bluebaltjim's Avatar
koni's with eibach prokit, stock alignment(im too lazy to change it btw autox and daily driving), hoosier a6's 225/45/15 all around with 38lbs front and 36 lbs rear on 15x8 wheels with a +15 offset total wheel and tire weight is 32lbs(i know ss's can't run 15's), ebc rotors with hawk hps pads in the front stock rear drums, progress rear sway bar.
RaginChopsuey
Oct 27, 2015 01:27 PM
patooyee
Oct 15, 2015 05:11 PM
ThoR294
Oct 4, 2015 08:44 PM
cw383
Sep 30, 2015 12:41 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
