Autocrossing the SS
Autocrossing the SS
Yesterday I ran against the guy who placed first at the SCCA Vail National Tour event and the guys who were 5th and 6th at Vail -- the first 6 finishers were all within 2 seconds. I ran Vail with ProKit springs, Konis, Progress rear swaybar, and old Kumho 285/35 x18s -- and I was 6 seconds slower than 1st place.
Yesterday, I have the new 550 lb front Ground Control coilovers, new 650 lb rear springs, still on Konis, the Progress bar removed entirely, and new Hoosier 285/35 x 18 tires -- 1st time out with the complete new setup. Wow! Huge difference, car handles like a completely different vehicle. No under-steer, no over-steer, very neutral, everything seemed slower than it used to feel -- but I was faster every run. I was 2.5 seconds slower than 1st place and about 1 second slower than 2nd/3rd places -- a huge improvement.
Overall best times times for DSP (a relatively short, tight course -- I do better faster):
(VW R32) 1st -- 36.211
(BMW 325) 2nd -- 37.803
(BMW 325) 3rd -- 37.969
(me - SS) 4th -- 38.849
1-3 are driving very sorted-out cars that they've owned and run for several years. This is my first year with the Cobalt and the 1st run with a decent setup. I'm no longer as worried about finishing last at the Nationals in Lincoln.
Scott
Scott
I've already bought a Stage 1 so I'm just waiting on GM to get the flash ready -- then more HP and more important, more torque.
Scott
Excellent story! Good details.
I'm thinking about doing my 1st one this weekend. 09 SS Sedan..
It's completely stock etc... Does this mean my tires with 11k miles on them are going to be useless?
I see so many going with Hoosiers... Do you use a separate set of rims for these?
Your street tires are fine. You'll know when they're holding you back, and that will be several events or even seasons from now.
Once your streets wear out, consider a set of grippier street tires rather than full R compounds.
You'll want the maximize grip in the front by keeping the tire patch flat. Too much air and you get tires worn in the middle and too much wheel spin. Too little and the tire will roll over on its sidewall and give mushy response. 42 would be a good place to start.
At the same time, you want the rear tires to give up grip before the fronts do. That means shrinking the contact patch by under inflating or over inflating the tires. Most people choose to over inflate the rears; it tends to make the back of the car livelier. I like to remove pressure, though; oversteer tends to be more progressive and controllable. Try 5 pounds above or below your front pressures to start.
You can set your pressures, but you need to adjust them, more importantly. You'll probably gain three or four pounds on just your first run. Hot sun and back-to-back runs can drastically raise pressures so that
Your first investment for autocross should be a good tire gauge.
But if this your first event, you'll really just be learning how autocrosses work and deciding whether or not you want to come back. Concentrate on the course and learning a set of skills you can build on. It's very much like skiing, and your first event is the bunny hill.
If it's not fun, you're not doing it right. Have a blast!
Have Fun!!!!!!!!!!
Well I didn't get last.
I was 2nd in NV1-D Stock (Novice 1, stock cars)
Here are links to the 3 vids I took
1st Run http://www.youtube.com/watch?v=Ssji_jFNk4s
(forgot to record 2nd run)
3rd Run http://www.youtube.com/watch?v=jf3t05m-hxs
4th Run http://www.youtube.com/watch?v=lBT4bo4l71Y
sounds like a lot of understeers from the video...
i would get a good alignment.... if you plan on running in stock class.. you can get another
degree of negative camber in the front by modifying the front strut a bit...
Yes, lots of understeer....but probably mostly due to my driving aggressively.
I know caster/camber.....what type of 'modifying' do you mean?
like this.. http://www.pbase.com/jt_kgy/image/11...0/original.jpg
modify according to GM's service manual..so you stay within stock class..
looked agressive yet smooth, great job. Don't forget when you hear the tires screaming like that just unwind the wheel just a little bit. Usually when you do that the car won't turn any less you'll just reduce the slip angle.
Scott
Scott
Since these tires/wheels protrude slightly outside the body line, I needed significantly striffer suspension to avoid rubbing the tires with the body -- besides it's a better autocross setup. I'm running Ground Control coilovers with (the racing suspension) 6" 550 lb front springs and 7" 650 lb rear springs -- over Koni adjustable strut cartridges up front and Koni adjustable shocks in the rear (Koni yellows). I run the stock front and rear sways.
Last suspension item: I use a set of modified B&G camber plates (that I modified - these cost about $200 from Gravana/B&G), on the stuts to let me mod the camber as much and as often as I want. They work well.
No problems with the front calipers, brake lines at either end, and shocks in the rear. I clear the front struts by about 1/2".
I met my goal at the SCCA Nationals, I've had only run the car once with the above setup before the Nationals, my goal was to not finish last -- I didn't. But I was darned close -- I finished 28th out of 31 DSP cars. The competition was truly impressive!
I just finished the last local SCCA event today and I beat the next DSP competitor by about a full second (I ran a totally different camber and tire pressure setup than I used at the Nationals, plus hit tires -- it's much better). This means I'm first in points in DSP for the Rocky Mountain Region this year.
I'm looking forward to next year's Nationals -- they'll be in Lincoln, NE again. I'm taking a co-driver this time so I can run with hot tires (my Hoosiers never got above 85 degrees after the 2rd run - today my tires were about 130-145, with a co-driver). I'm still going to hope I don't finish last, but I'm shooting for at least mid-field next year. Finally, getting the Stage 1 -- whenever it finially shows up, I've been waiting since June! -- with the extra torque/HP will be very nice!
Scott
scottherbert,
In your opinion... would there be that much work to get 265 street tires to fit?
I'm wondering about the work needed to run in STX...
I assume your 285 is v710... which should be much wider than a 265 street tire.
So..I might just hold on to the stage1 kit for a while...(it's not even fully released yet anyway..so it might not even be a matter of choice!)
I think I was to stay in DS as long as possible. Cheaper class to run in.
Here in lies the dilemma! To me, it's a lot more rewarding to go run the car through its paces on the autocross track than take a chance of losing my license on the street...
What does the stage #1 do??
Does it modify boost?
If not, you can save it for STX class
