First auto-X of the season!
Well, started off with a school on Sat , then an event on Sun!! Wooo, good way to get back into things!
I got bumped into STS with my CAI, and lots of other cars in my class...this car has soo much power...we had tons of sloloms and lane changes, two chicago boxes, and two small sweepers...Bout a 89 sec course for those CSP miatas...i got one battle scar
Four runs total, out of abuot 120 cars...
Changed my tires, so didnt get to stay for awards....
Positives: Sway bar kicked in around the pivot cone! Woohoo, and LSD really helped...
Car is more nimble than I thought it would be
Negatives: Must break a lot earlier on these BFGrench Sport tires
Told i needed to get the camber kit!
Other than that, fun time had by all! Ready for the next!!
nice, my first autox with the sway bar is this coming sunday. you might also try elongating the holes on the strut top mounts to get some extra neg camber and a little toe out. good luck chasin those f*ckin miatas(im running csp this year),
autocross parts
if u look on the gm performance division homepage u will see items that will make that suspension perform better a must is the spherical joint in the front lower control arms
You should actually be in STX class. We had a BIG debate about that here, then read and re-read the rules. In all honesty, I prefer DSP to either. That's what I run in with mine because I run R-comps and I LOOOOOOOVE that class. A lot more closer in competition.
Seoulgirl07, I gotta head to the triangle, down here is fun, but sounds like a blast up there.
I put crashbolts (excentrics) in the lower (upper of the 2) strut bolts and have a max adjust up to neg 2.2* .
http://www.thscc.com/autocross/event...0311class.html
This is the class results...
http://www.thscc.com/autocross/event...-0311indx.html
Indexed...
Is there anyone else out there that cares to share their autocross alignment specs for their cobalt?
Anyone doin Triad this weekend?
Indexed...
www.auto-x.com
at Greensboro colusiem...not that many entries yet, only one in stx
Second autocross at the Greensboro coliseum...horrible for the cold, hard to get any tires to stick, but great improvements from my last race
...i was only 3 sec off the best times i saw
those with r-comps too....slippin and slidin!
those with r-comps too....slippin and slidin!Thread
Macgyver2484
Sep 23, 2015 11:36 PM
