Genuine powell race parts: Trap door oil pan for racing and autox
LNF and LSJ.
Stock pan: http://i857.photobucket.com/albums/a...ril2006025.jpg Trap door fabricated pan: http://i857.photobucket.com/albums/a...e/DSCF1725.jpg http://i857.photobucket.com/albums/a...e/DSCF1729.jpg No two pans are exactly the same, they are hand made, but the configuration remains the same for all. Cobalts have a wet sump pan, the LE5 pan is superior to LSJ for slosh control, but sustained hi g cornering, braking and especially sudden elevation changes followed by braking can cause oil starvation at the oil pick up and catastrophic engine failure. The trap doors permit oil to flow easily in to the pickup, but keeps a head of oil at the pickup This hand crafted race modified pan I expect to be priced under $300, the issue really is what to do about core pan returns ( or lack of return ) and the shipping costs. Until we have a strategy for that, (mid September) I cant say what the final price will be. We will have two pans in stock at all times, as we do now. |
John:
Is the oil capacity still 5 qts, or did (or can) you go back to the 7 or 6 qt pans of the earlier LSJ motors? I'd really like to have a 7 qt capacity if I had the option. I had an 04 LSJ Redline with a 7 qt capacity, an 06 Redline with 6 qts, and my 09 LNF Cobalt only has 5 qts aboard (at least according to the specs). I'm of the opinion that more oil is better than less -- I'll pay for another couple qts... I'm interested regardless. I've been worrying about oil starvation for some time. Thanks, Scott Herbert |
is this something that should be of concern for 2.2's? and if so, is it an option for us as well?
Awesome. Glad to see you are going to start offering these!
I'd like to see these available for the 2.2 as well...
it is. no problem. cheers
powell race shop is the king!!!!lol thanks for everything you guys have done for the community
Just curious, could you install something to monitor oil temperature in the new pan? I realize we would need a gauge to hook it too, but I would be _very_ interested in grabbing one of these if this could happen.
Originally Posted by tommyk
(Post 6135985)
hmm some new mods to add to my list
7 Qt. pan on an LNF??
Would it fit without interference, and is there enough material to warrant the welding changes? If so I get to go on a scavenger hunt.
Also need to know what I am looking for (special shape, protrusion, part number, etc....) |
I'd have to send in my turbo swap pan then for lsj. Nifty idea though.
I do have 2 spare lsj pans if u desire |
Originally Posted by Jrg77
(Post 7462936)
Have one on my cobalt and it's a great part.
the LNF dipstick tube is different diameter and the boss is a different height compared to LSJ Buick also. I dont recommend running the LSJ pan in an LNF but if you do a simple tube modfication takes care of this should you wish to run the LSJ pan. Somewhere on here I posted the differences. I can also say I paid the price of a rod bearing not running a trap door pan with YYZ springs. The lap times were stunningly fast corner speeds higher, all left the oil pickup gasping for air.
boom |
I need one of these fancy things.
(Post 7463638)
boom So modify an LNF pan and it can get the oil control stuff done. Would an Accusump provide extra oil capacity? Is extra oil capacity needed/warranted for track day activities? |
I became a victim of oil starvation even before I got my YYZ springs, also on a track. Spun my rod and main bearings and wrote off a crank. I immediately installed Powell's oil pan after that.
As for adding oil capacity, I'll be installing a front mounted oil cooler in the next month or so. Mr. Belvedere on here supplied the flange you need to do that. (thread here: https://www.cobaltss.net/forums/adva...cooler-312659/) I'm expecting to add at least 3 quarts of oil with this setup, which is a nice side effect since I'm mainly installing it to curb my temps at the track. |
Accusumps are usually bandaids. Before they engage a lot of times it's too late
(Post 7463638)
boom Jim |
Just sent him a message for you.
I have a couple extra pans sitting here. One is new
JIm I some how dont see an email from you. John@powellraceparts.com 175.00 exchange or maybe a little more no exchange as we are using new pans these days the fabricator complains about oil in the alloy when we use old cores to make new trap door pans...so...LNF or LSJ ? please specify . Cheers and thanks to Andrew Carr for letting me know you were asking, things are busy around here, I am not on here as much as usual
I may have to get in on this for my next motor build. I have an LSJ pan just laying around I may have to send you this summer.
(Post 7463905)
Doh. |
