Looking for info on the front strut-grind 'mod'
I auto cross and would love to see how much negative camber I can get out of this with the strut grind. It is mentioned in the Chevy field service manual (from what I hear) so it is considered a legal 'mod' for stock class.
Any info, pics, explanations on how to do this would be greatly appreciated.
I've got my first event on april 7th so gonna be doing this and putting my new rear Konis on before then. As I understand it when you pull the lower bolt on the strut it is stamped to the certain amount that you can legally (SCCA stock classing) grind. I have seen pictures online, just can't find them now.
Thanks qwik. For the people who have done this do you know the torque specs for the strut to knuckle nuts? Also, what did you guys use to open the hole up? Would a dremel work or did you just use a circular file? Also, anyone know the size wrench/socket for the nuts, I took a quick look at them today and they seemed fairly large. ....Yes, I know I need to get the shop manual.
Thanks.
Thanks.
Thanks.
Thanks.
Yes, they're fairly large, about the same size as the lug nuts -- in fact you could use a lug wrench. I don't remember the torque specs, however, I now use a Goodyear electric impact wrench (from Pep Boys -- best investment I ever made) and torque them until they stop. Yeah, I know, it isn't 'torqued' to spec, but I change stuff up front so regularly (just did again this morning) that I don't bother to torque the strut bolts any more. BTW, the swaybar endlink bolt is the same size as the strut bolts.
Scott
Thanks, I have impact sockets for my lugs and a few sizes bigger so I should be set. I have a craftsman cordless impact and it was also on of the best investments I have made. Makes working on everything so much easier. I have my first auto-x with this car next weekend and will probalby leave it stock for the first event, and maybe the weekend after do this. At the very minimum it should improve tire life. Thanks again.
No reason you couldn't leave with that much camber. It will cause excessive wear on the inside edge of the tire though. You might also have to be a little more careful in the rain as you are decreasing the contact patch in a straight line.
Last edited by F_Imports_09tc; Apr 17, 2010 at 12:13 PM. Reason: Automerged Doublepost
First event was good, I finished in about the middle of the pack (raw times) out of about 160 people. I haven't had time to grind the strut holes you yet. I'm still on the stock conti's, and thought that they were pretty decent for an OE tire. There was some rollover even when they were pumped up, but I thought they did pretty well. I don't know how much the mod will help my times, I need more time behind the wheel of this car before I can start comparing times with camber adjustments.
For those that did this "strut-grind" mod on stock suspensions... whats the ideal camber?
I have -1.8 but it's not quite enough and still having lots of tire sidewall rollovers... so I'm
planning on getting a bit more camber but also concern that too much might hurt accleration
and braking.
Suggestions? -2.0? -2.2?
and braking.
and braking.
and braking.
Last year I ran 2.5 on the Nittos. This year 2.375 seems to be the sweet spot.
Get a good temp gauge and go for it.
