Autocross and Road Racing Road racing is not “street racing”
Understeer and Oversteer
Old May 24, 2007 | 03:43 PM
cheesetits's Avatar
Can someone explain what over steer and under steer is?
Old May 24, 2007 | 03:44 PM
MachiBLue's Avatar
http://en.wikipedia.org/wiki/Understeer
http://en.wikipedia.org/wiki/Oversteer
Old May 24, 2007 | 03:48 PM
alleycat58's Avatar
Generally FWD cars understeer (i.e. when you're turning, the car wants to pull straight instead of turning, especially when you accelerate) and RWD cars oversteer (i.e. when you're turning, the back end of the car wants to slide out when turning, especially when you accelerate...which is the whole physics behind drifting).
Old May 25, 2007 | 07:53 AM
SoloZ/SS's Avatar
RWD cars don't allways over steer but depending on the way you drive they may or may not. Alot of this is totally on the driver especially if you allready know that your car is known for understeer, if you brake more before the corner(this is from my experience running on street tires) and then drive out of the corner you should be allright and have less understeer but if you go flying into a corner and hardly brake at all you can expect a good helping of understeer.
There are a few ways to correct understeer in a front wheel or all wheel drive car, the cheapest way is with air pressure in the tires. Alot of people are devided on the direction you go with the rear tires but I have been going with less and less air in the rear tires recently, some swear by going higher in the rear end but I have found that when the back end does go it goes fast and some people may not be able to react fast enough.
Old Jun 10, 2007 | 07:09 PM
Gene K's Avatar
Understeer is when you hit the wall nose first!
Oversteer is when you hit the wall tail first!
In circle track terminology. Understeer is tight or a push. Oversteer is loose.
Old Jun 10, 2007 | 07:16 PM
vB00STw's Avatar
Understeer is when you hit the wall with the front of the car. Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
from my aim profile lol and as Gene K said above
Old Jun 10, 2007 | 07:17 PM
TVS_SS's Avatar
understeer / oversteer should only be commented on in "steady state" cornering
utilizing the throttle and brakes can put any vehicle into understeer or oversteer.
Old Jun 10, 2007 | 08:56 PM
SoloZ/SS's Avatar
good point
Old Jun 11, 2007 | 07:41 PM
thmotorsports's Avatar
Dude...that is one of the funniest things I heard the whole day.
I love it!!!
qwikredline
Jun 7, 2014 04:45 PM
mongorat427
Dec 13, 2010 08:18 AM
brandondrecksage
Wheels and Tires
Dec 20, 2008 12:34 AM
kissmySS
Aug 26, 2006 12:25 PM
