BuyHIDs.com BuyHIDs.com is a Supporting Vendor of CobaltSS.net
Contacts: mkulrey13
3rd Brake Light LED Kit Anyone?
Old Jul 31, 2010 | 05:18 PM
mkulrey13's Avatar
So, My partner Steve & I were talking about getting some LED kits made for the third brake lights. Would this be something the community would be interested in? As for pricing, Not sure yet but these will be very affordable for everyone. Most likely plug-n-play as well
Here are some pictures.
Old Jul 31, 2010 | 05:20 PM
Blown07SS's Avatar
That's what I'm looking for
Old Jul 31, 2010 | 05:27 PM
ei3dag3's Avatar
so what happens when you run out of impalas led boards? :p
it looks good, i did mine a while ago.
Old Jul 31, 2010 | 05:37 PM
tanelk's Avatar
i want that
Old Jul 31, 2010 | 05:41 PM
mkulrey13's Avatar
We dont use Impala LED boards which are roughly 60-80$ a peice. We make our own boards.
Old Jul 31, 2010 | 05:57 PM
koch1ar's Avatar
what price are you thinking?? how long will you warranty them??
Old Jul 31, 2010 | 05:59 PM
springerdesigner's Avatar
depends on price.
Old Jul 31, 2010 | 06:00 PM
ei3dag3's Avatar
DAMN!
i got mine for 17 bucks shipped. 60 really?
holey ****.
they look the same as mine, so i just guessed.
of course i had to wire mine in and all that, but it wasn't a big deal.
a plug in play would be great though.
good luck
Old Jul 31, 2010 | 06:14 PM
yel-low's Avatar
What does it look like at night very interested
Old Jul 31, 2010 | 07:08 PM
mkulrey13's Avatar
Thats what the impala brake lights cost new. Not very cost affective when you only need the LED board. We'll design our own. Looking to be under $30 hopfully.
Old Jul 31, 2010 | 07:18 PM
jhop16's Avatar
I'd be interested, I unplugged my 3rd brake light cuz it doesnt go with my LED tail-lights
Old Jul 31, 2010 | 07:26 PM
link_630's Avatar
I'm interested
Old Jul 31, 2010 | 08:54 PM
ei3dag3's Avatar
for less than 30 bucks i'd have def bought yours.
especially if it was plug in play.
Old Jul 31, 2010 | 09:28 PM
bbrewbaker's Avatar
Damm i should of waited.
Old Jul 31, 2010 | 09:46 PM
buellfooll's Avatar
Would that include the resistor to retain cruise? I did my own retro and learned the hard way about needing a resistor. But $30 PnP WITH the resistor would be good.
Last edited by buellfooll; Jul 31, 2010 at 09:47 PM. Reason: Automerged Doublepost
Old Aug 1, 2010 | 12:43 AM
Cobalt08LS's Avatar
i had the led one that modern performance use to sell but it randomly stopped working so yeah
Old Aug 1, 2010 | 01:17 AM
TommyP's Avatar
AWD > FWD
I'm interested
Old Aug 1, 2010 | 03:52 AM
reaper89's Avatar
im interested, as long as its PnP
Old Aug 1, 2010 | 11:07 AM
proZak's Avatar
my 06 ss/sc had 3rd led from modern performance and worked fine.
When I bought one for my tc the 3rd brake light would stay slightly illuminated when parking lights where on,
and it would stay dimly light for ten minutes after the car was shut off
if theirs a way to fix this i would order one!
Old Aug 1, 2010 | 11:35 AM
ADIDASS's Avatar
You only need a resistor if it blinks. I wired mine in with no problems from a monte carlo, no problems what-so-ever.
On the other hand, I had to use resistors later for my new taillights because they blinked and it was hyper blinking.
Old Aug 1, 2010 | 11:39 AM
Koenreich's Avatar
<-------- Interested.
Old Aug 1, 2010 | 12:01 PM
mkulrey13's Avatar
Ok guys, I got the design down and made one quickly. Just ordered all the parts. Would anyone be interested in pre-ordering?
Old Aug 1, 2010 | 08:03 PM
kidcrash603's Avatar
I've had this on my car for a while now, and I use cruise every day. I have no issues.... What sort of problem did you have?
Old Aug 1, 2010 | 08:40 PM
arman14's Avatar
How much?
Old Aug 2, 2010 | 12:38 PM
buellfooll's Avatar
I have a 09 SS so I can't comment on ALL cars. This is what happened when I installed an aftermarket 32 LED strip into my lamp housing. I didn't have much hair BEFORE this episode but after the troubleshooting required to fix it I have a lot LESS now.
If you will read your owners manual you see that to ARM the cruise control you must hit the brakes once after starting the car to allow the cruise to be turned on. This is a safety feature built into the system to verify that the brakes are working BEFORE ALLOWING the cruise to be set because the BRAKES are the primary method by which the cruise is turned off. The system uses the High Mount Brake Light to sense the brake function. It does this by sensing the current draw across the High Mount lamp. Because there is so little resistance across an LED there isn't enough current sensed to allow the cruise to turn on. This is the same condition that causes rapid flashing LED's. If you used a LED lamp from another vehicle it probably has the resistor circuitry built in. There's plenty of reference material around.
This is a quick reference. Scroll down to the bottom;
https://www.superbrightleds.com/cgi-...rake-turn.html
If something had been available, when I did mine, for $30, including shipping, I would have jumped on it.
