Custom Tuning Results/Writeup!!
Originally Posted by distillion
Originally Posted by DWK5150
Yes it would but he even said in his first post that the ECM will be locked when they are finished tuning.
Originally Posted by meister
You can ask questions about the stock logs and I will be happy to answer what I can.
With a mustang dyno, you cant change correction factor between non, SAE or STD like on a dynojet....it is always SAE. The only correction that gets applied is frmo temperature, humidity, and baro pressure....we have a weather station inside the building that samples all these numbers.
Originally Posted by Mase
why you afraid I'll see some number that don't match your dyno result. I'm not asking for your tune, I can send you my log files from when I dynoed at TAG
Originally Posted by ninja44
I just might come see you next spring for a custom 2.7 pulley tune if you don't mind
WOW.... can anybody ever just let somebody post something on here without starting a bitchfest..... this is starting to get real annoying... this is why we keep losing the guys that actually know what they are talking about
No, because you can see timing and other variables I do not want you to see. If you have a problem with it, dont post
The log file is an output much like dyno graph, the input is what really matters
With the 2.9 it boost about 120 Kpa and the 2.7 gets 140 Kpa (just over 20 psi) I'd actually like to dyno it to see what the car is doing (AFR) i get no detonation but would like to get a dyno to see what can be improved. I told myself I was done doing things to the car but damn my bike makes my car feel slow
seeing what a car runs timing wise doesn't mean ****...I know a Redline that runs 26* up top but how do you get there is the problem.
If you want me to answer questions about the logs, let me know..
If you sign a waiver, and really want us to tune this much boost on pump gas that is up to you
You have my dyno charts, air fuel charts and that is all you will get....as I stated, my logs and my tune files are my property and I will be locking all my files too
Paul does not want to post log files so respect it, if you don't like the #'s then carry on thanks for coming out. It started as a thread about Steeda doing this car community a good deed by developing a tune and now it's this ****. Now i have to sift through 4 pages of **** to read relevant info about Steeda's tune
