Manitoba SS 2014
Old 09-17-2014, 11:31 AM
  #2476
slapbetcommissioner's Avatar
Steps
1) buy beer
2) jack up car as high as possible
3) unbolt subframe and transmounts
4) bleed your turn signal fluid.
Bolt it back up and see if it helps
Old 09-17-2014, 11:57 AM
  #2477
InfraRedline's Avatar
Oh nice! I don think you're gonna have a problem now being on 30psi lol
I'm going to make it solid on 32 maybe even 34 lbs, maybe. He makes 632whp on 36 lbs, so I have my work cutout for me!
Old 09-17-2014, 12:19 PM
  #2478
KMO43's Avatar
That would be awesome to see!
Old 09-17-2014, 12:27 PM
  #2479
This time of year is going to be tough from a 40mph roll. It's near 80* during the day but cool at night so the pavement doesn't stay real sticky. I think I'll get worked from a 40. I'll have to get a 40 and 60 out of him.
Old 09-17-2014, 12:44 PM
  #2480
KMO43's Avatar
Its the end of the season warm those r888s up!!
Old 09-17-2014, 12:47 PM
  #2481
Oh I'll try to get em sticky lol just don't have the hot summer night temps and hot ground to cooperate with me
Old 09-17-2014, 01:17 PM
  #2482
Got Bewst?
Bluelightning's Avatar
Originally Posted by tomj77
Wanna do a quick how to from memory so I know about what I'm in for?
Get your hands on the lsj build book. It will show you step by step how to do it. I have it on PDF if you can't find it.
Originally Posted by KMO43
Never said I'd part with them either but if you fed me enough beer possibly
Then why did you mention you have black seats? Lol
Old 09-17-2014, 01:40 PM
  #2483
KMO43's Avatar
To get that reaction from you.
Sounds like we are gonna get some runs in on Sst night! Won't be anything like Taylor's but I how I can get some battles in
Old 09-17-2014, 01:49 PM
  #2484
Got Bewst?
Oh lol. I'm not dying for black on black seats. Just a preference if possible. Silver and black will still look good.
Old 09-17-2014, 01:56 PM
  #2485
tomj77's Avatar
So what to u get if u want it to last lol.
Old 09-17-2014, 01:59 PM
  #2486
tomj77's Avatar
That last one was for KMO43 , forgot to reply
PDF would be nice, how much?
Old 09-17-2014, 02:46 PM
  #2487
Got Bewst?
I can just email it to you. I have it on my computer.
Old 09-17-2014, 07:03 PM
  #2488
tomj77's Avatar
Sure. I'll on email unless it's already on file here
Old 09-17-2014, 09:58 PM
  #2489
tomj77's Avatar
pod update, or first post, idk if i did already
ok see what u guys think of my pod project so far, long way to go yet, but this is what I got so far.
Old 09-17-2014, 10:03 PM
  #2490
tomj77's Avatar
that's all figerglassed. need to bondo and fill and sand and more sand yet. fiber glass it basically sanded to the shape I want, need a little more fine detail, but ill probably do that with bondo work.
Old 09-18-2014, 12:09 AM
  #2491
Looks good man! Nice work so far. I've seen one other dash done similarly. I believe it was scythe snakes. His just didn't block the vents I believe. Pretty sure he paid like 1k for it too. So hell of a bargain hah.
Old 09-18-2014, 12:44 AM
  #2492
KMO43's Avatar
Good work Tom also remember glazing putty is your friend for small pin holes and such I usually prime sand putty repeat
Old 09-18-2014, 08:40 AM
  #2493
tomj77's Avatar
Ya I got some glazing puddy, I guess that will be after some bondo and sanding. I gotta fix a few larger holes in the fiber glass where there is a void underneath caused by the bad way I fiberglassed at the beginning. Once those are fixed up ill do some bondo.
Old 09-18-2014, 11:08 AM
  #2494
Lookin good man!
Old 09-18-2014, 05:33 PM
  #2495
A little comparison on a bored day at work. Here is a Virtual Dyno graph of Dustin's car and my car overlaid. Take these with a grain of salt, but I do know that with how it is setup right now it has gotten me within 2% accuracy and tighter on 3 setups/cars that I have logs of right before they went on an actual dynojet. My graph starts later because I didn't go WOT until 4850 rpms or so and full boost hits around 5200 in this run. My weight is so high because I had 3 people in the car, one at 230lbs, one at 180lbs, and myself. Then the usual stuff like a pretty full fuel tank and typical **** in the car. Anyone familiar with virtual dyno knows what I'm talking about.
Dustin's car - Red line:
Stock Gen 3 2.0 - 9.2:1 CR, ported head, ZZP S2 turbo cams
S252et turbo setup
94 octane pump gas - no meth
23 psi, 16* total timing, 11.8-11.9 AFR
Still revising the tune, but it's close. Car is begging for a bigger turbo/meth with how its flowing.
My car - Green line:
Gen 3 2.1 9.7:1, ported head, ZZP S2 turbo cams
s259et turbo setup
E85 fuel
30 psi, 20* total timing, 11.3 AFR
Usually run to 8k, power usually peaks at 7600-7700
Old 09-18-2014, 06:20 PM
  #2496
Got Bewst?
I'm the green line incase you guys are unsure
Old 09-18-2014, 08:14 PM
  #2497
Lol. Figured those cams were worth at least 200whp.
Old 09-18-2014, 10:23 PM
  #2498
Got Bewst?
Right! Not bad though considering I'm only on 16* timing and 23psi.
Old 09-18-2014, 10:53 PM
  #2499
Lots of room for more boost. Meth and timing you will be taking well past 400
Old 09-19-2014, 10:16 AM
  #2500
Easily! A few degrees up top will get us there on the same boost. I think you should hook up the meth for some pulls when I come up! Then a bigger turbo over winter and 450whp will be nothing.
Quick Reply: Manitoba SS 2014
