Manitoba SS 2014
#1851
Got Bewst?
Blue if you stil don't have your meth when we come down and if the roads are ok I'll run you. I know I have no chance when you have meth spraying but I saw what you did to Jonathan in your TVS build so I want to try and see if I can do a solid for LNFs and Calgarians. I don't have my hopes too high but think it'll be fun either way
#1852
well I didn't spray in my mouth but I did rig it up on the windshield yesterday and sprayed that as I was setting my activation. if ur mouth is on it ya, It would be bad, but a little ways away, make the pump come in slowly, I think u could do it lol just gotta install the taps. but only get beer under boost.
Here you go tom on the left is a STG1 timing basically the same as stock and on the right is mine on meth
#1853
did some msds lookups on some Canadian tire windshield washer fluid to find cheaper methanol. here are the 2 best I found for nice and cheap.
rain-x deicer = 40-50 % methanol $4.49
motomaster -45 = 40-50 % methanol $3.79
motomaster is cheaper than getting pure meth and mixing.
for whoever wants it cheaper.
#1855
#1857
OK so it's rpm vs load% so say at 3000rpm @ 100% load it's at 23* on the stock profile. Since meth sprays at high load I changed the 200% area because that is the full throttle part of the graph where I know the meth is spraying. Now to get more complicated I could make the same table rpm vs load% and datalog my meth flow from my AEM gauge to be able to see how much and where the meth is spraying to be able to adjust the lower parts of the table too
#1865
Nope looked clean and brand new it was seized and wouldn't move at all even taking it apart as much as I could didn't help. Just buy a couple LE5 TBs from mongo he sells them for $50ea running washer fluid you'll save that $50 in a couple months over buying real meth
#1867
#1869
I built a meth injected pre TB M62 in 2007 and in 2012 when it was sold I had to replace the M62 as long term corrosion from the meth had seized the boost bleed butterfly shaft. The TB was still good. Thats all I know. I would suggest that replacing the TB is a good idea to eliminate that part of it. I hate to just replace parts but there is no doubt that few folks have experience with true long term effects of meth use.
I published a chart of wwaf a long time ago on here compiled by area47 with some meth contents. Rainx is not a good one to use imho. This chart was done in 2007 so its old and probably needs to be updated
#1871
#1872
Timing is one of the last things you change. First set everything how you want it boost, cam timing ect and then start slowly adding timing. The knock table on my scanner is the same as that table so if there is any knock you can copy the knock table and subtract it from your timing table in HP Tuners
#1874
I love the new saying "******* James Rakes tune" I'm doing baby steps and if you look at the 2 timing tables I am running less timing down low from previous tunes but that was with my old leaking intercooler. I was basically setting up my fuel trims and clutch went before I really tried tuning. I have the RPD and I always have it set on knock since I'm most worried about that.
#1875
