Manitoba SS 2015
Old 02-24-2015, 01:08 PM
  #401
Got Bewst?
Bluelightning's Avatar
That's the thing. Kevins never fully plugged. Just lost some flow in 1 nozzle. And that's why I say in his case the fail safe probably wouldn't pick it up. The loss of flow would be minimal having 3 other nozzles spraying at the same time. But it was enough of a loss to take down a cylinder.
Go get greedy with meth it doesn't bother me any. But I've learnt my lesson doing so.
Old 02-24-2015, 02:35 PM
  #402
KMO43's Avatar
I agree the failsafe will not pick up on a plugged nozzle and that cyl is done. It'll just up the flow to the rest of the working nozzles
Old 02-24-2015, 03:29 PM
  #403
tomj77's Avatar
Ok now I just wanna prove u guys wrong lol but u may be right , I'll try anyway. Not on my car though. Sitting on a bench.
Old 02-24-2015, 03:31 PM
  #404
tomj77's Avatar
U can set the failsafe to detect even the tinyest amount of change if u want. Has no one here ever used it or something? The aem one.
Old 02-24-2015, 04:03 PM
  #405
Got Bewst?
Try it out. I bet flow rate won't change on the fail safe. Like Kevin and I said it'll just push more fluid through the other 3 nozzles.
Old 02-24-2015, 07:58 PM
  #406
KMO43's Avatar
I know how it works I was the first to have it and suggested it to you. I don't believe you can have it set that close because the style of the pump isn't super accurate in the first place
What I did is turned up the pressure so my 625 cc nozzle flows 1000cc flow will go down but by enough to trip the sensor???
Old 02-24-2015, 08:34 PM
  #407
cluelessk's Avatar
Don't re-engineer the wheel here.
There is a reason why it's not common practice. In theory it sounds great but it's too much risk on a already risky system.
Old 02-25-2015, 07:09 AM
  #408
tomj77's Avatar
I'm not gonna do it, but it fun to try figuring it out. May just end up making manifold take 4 fuel injectors and sell it to whoever needs that for some high hp lnf
Old 02-25-2015, 09:58 AM
  #409
KMO43's Avatar
Sorry Tom I forgot I said I'd post the link to that bung well here it is you install this where the vacuum hose is right over the throttle body just grind it smooth
Additional Injector Holder Kit : atpturbo.com
Old 02-25-2015, 11:12 AM
  #410
tomj77's Avatar
The heck with that, I'd install that in all 4 runners. But that's expensive bung. The vac nipple would need to be moved. Hmmm, I think I may make this, who would buy?
Old 02-25-2015, 01:31 PM
  #411
farmerz24's Avatar
How does the flow get "upped" to the remaining injectors? These pumps are self regulating are they not?
as far as i know, these pumps have an internal regulator to like 100 or 200 psi, depending on the pump. when one nozzle is clogged, pump pressure would remain the same and therefore the remaining nozzles would flow the same.
think of another example: If you were to plug or even remove one of your fuel injectors in your fuel system, the flow to the others would not increase, and would remain the same. the regulator would sense the increased pressure and would then react by lowering the fuel pressure back to what it was, had a clog not occured.
Same thing is happening here.
And I dont know what the range limits are on the failsafe for % of flow changed in order to set the failsafe, but one nozzle of 4 clogging would be a 25% rduction in flow. Had this nozzle been only "half-clogged" or flowing half of what it should, then the flow rate would decrease by 12.5%. is this within the ragne on the aem's failsafe detection?
Old 02-25-2015, 01:39 PM
  #412
Got Bewst?
Ohhhhhh Chris is always lurking! Lmao
Old 02-25-2015, 01:50 PM
  #413
Kennyspec's Avatar
Old 02-25-2015, 01:54 PM
  #414
Got Bewst?
Oh **** now we got one of the OG's stoppin in! Lol
Old 02-25-2015, 02:00 PM
  #415
yellow dragon's Avatar
Lol
Old 02-25-2015, 02:08 PM
  #416
Got Bewst?
We had better change the subject before Kevin just makes face palms the entire time lol
Old 02-25-2015, 02:39 PM
  #417
Post number 8 for chris. 2 more and he getz a stickarz
Old 02-25-2015, 03:00 PM
  #418
KMO43's Avatar
No you can change the pressure I have an AEM Failsafe gauge and am on a 625cc nozzle but I upped the pressure to full (300psi) and am getting 1000cc out of it. It's the same as adding more fuel pressure to make injectors a bit larger
Old 02-25-2015, 05:08 PM
  #419
tomj77's Avatar
The aem gauge can be set to trip wherever u want it, u program it with software and use a graph to plot ur failsafe threshold. I'm not gonna be using the system, but I will check into this anyway just to know. If it does trip easily I may use the system. I think there is a lot of guessing but no one has ever checked if it would trip or not. It's possible that the other 3 injectors would just spray harder. What km says makes sense
Old 02-25-2015, 08:09 PM
  #420
slapbetcommissioner's Avatar
If the pump is regulated by pressure and not flow then theoretically it shouldn't cause the other rail to increase pressure and therefore flow of the other 3.
But the over all flow would reduce from the pump. That seems like sound logic.
Old 02-26-2015, 09:49 AM
  #421
farmerz24's Avatar
If pump pressure remains the same the other 3 injectors will not spray harder. Pump pressure needs to increase for this to happen
Old 02-26-2015, 12:01 PM
  #422
InfraRedline's Avatar
That is true. If it was a matter of volume staying the same then the other nozzles would have to move more fluid to compensate for the clogged nozzle to keep the volume through the regulator the same, but it is pressure regulated, so the regulator will just pull back flow since it will see a rise in pressure, which will decrease flow which of course decreases volume. Will it be enough to trip the fail safe is the only thing in question.
Old 02-27-2015, 11:40 AM
  #423
Friday woohoo
Old 02-27-2015, 11:52 AM
  #424
Yay! Except I have to work tomorrow, but only until noon lol
Old 02-27-2015, 01:58 PM
  #425
farmerz24's Avatar
since all yo cars be put away this winter, here is farmerz24's daily driver - running 24/7 rain, sleet, shine, or snow.
gm 3900 VVT pushrod into a 05 legacy gt. 5 speed AWD.
MS3-pro powered.
stock tach works by way of an additional circuit speaking to the MS3-pro via CAN communications protocol and spoofing the crank sensor input. This allows the stock tach to to work along with the stock DBW TB controlled by the SUBY ECU.
Also had to install outback king springs 1 inch lift and outback 225/60/17 rubber for the ultimate in ground clearance.
Quick Reply: Manitoba SS 2015
