Manitoba SS 2016
#401
Hey Tom was that you on Ridge Road?
Thare was a ton of whitish smoke coming from the car. Could smell it from my car with the windows up.
Anyway tires are starting to come apart. But sent a text to the seller and he refunded me all the money plus some to cover the transfer fee.
Now to order brakes. Called Max Brakes and can get front rotors and pads for $120 shipped. How do you like yours?
#405
Probably haha when was this? Yes I know about The smoke, it's gray, I'm having an oil burning issue I'm hunting down. Thinking it may be valve seals. Car smokes coming out of boost into vacuum, smokes when I take off oil cap, or when I blow into pcv fresh air hose. If anyone has an idea what that would be let me know. Valve seals probably. If it was last Saturday or Friday though that could have been when I seafoamed and was clearing it out of the engine, crazy amount of smoke
Seemed to be worse while cruising. Went away under boost.
#406
Was that u wingless?
So it does smoke while cruising. Interesting. Yup something is definitely wrong in that motor. That helps me Narrow it down. I'm thinking something is causing either crank case pressure or my valve seals are just done. Leak down and compression tests passed so that seems to be all that's left. Turbo seems ok but maybe not, I'll have to check it out I guess.
#408
Ya that was me. My tires are coming apart so I'd get a huge vibration from 90km/h. Ya any time you were off boost there was a steady cloud.
Just ordered rotors and pads. Went with the uncoated blanks. The rest would take a week. Didn't really want drilled rotors anyway.
#409
#415
Got Bewst?
So I think I'm gonna be the test pilot and try those Nankang NS-2R tires. I want the 120 tire wear ones which they are currently out of stock at Canada Wheel. I just emailed them 9 at night and got an email back 5 min later! Thought that was impressive. They will be in stock May 30th.
cluelessk (05-04-2016)
#418
I'm gonna stop by a good shop tomorrow and ask if they know, since zzp doesn't email back ever.
#423
Maybe I should check to see if that port isn't plugged. Anyway I may just end up buying another car, need a second one anyway for times like this, and then park the Balt and tear the motor apart or the head at least and build it or just fix it. At least I can do it at relaxed pace then instead of worry about getting it on the road asap
