Manitoba SS 2016
Old 05-22-2016, 04:54 PM
  #476
cluelessk's Avatar
So it's a bent wheel. Moved tires one side at a time and it went away. Kinda feel it in my seat now.
Anyone cruising tonight?
Old 05-22-2016, 04:56 PM
  #477
yellow dragon's Avatar
Sway Bar is a more Complicated job when you strip the bolt. Fml
Old 05-22-2016, 10:37 PM
  #478
cluelessk's Avatar
When it rains it pours...
Rear brakes wouldn't stop making noise. Battery warning light came on, drove to my girlfriend's place, slowly died while parked so I shut it off. Battery is flat.
Old 05-22-2016, 10:39 PM
  #479
Sounds like the alternator is shot if the battery died with the car running.
Old 05-22-2016, 10:46 PM
  #480
cluelessk's Avatar
Went and took a look after I calmed down. Serpentine belt snapped.
Old 05-22-2016, 11:04 PM
  #481
Doh
Old 05-23-2016, 09:24 PM
  #482
cluelessk's Avatar
Got it all fixed up. Took 2 trips to Parts Source, to return the rented tool that didn't work.
Bought a tensioner release tool and clip tool at PA. Wrench didn't fit with the adapter. Could just get the adapter in on it's own. Went back to PA and bought two wrenches. One that fit the adapter and used the 2 wrench technique. Had the belt on in 20 seconds.
Went back and returned everything no questions asked.
Old 05-25-2016, 12:12 AM
  #483
cluelessk's Avatar
Starting to think I got some air into my abs unit when bleeding my caliper the other day. Fluid level dropped way quicker than I thought it would.
Now to find a tech 2 for an abs bleed procedure.
Car just doesn't have the braking force it used to.
Old 05-25-2016, 02:28 AM
  #484
slapbetcommissioner's Avatar
What did you throw on for pads and rotors again?
Old 05-26-2016, 09:46 PM
  #485
Got Bewst?
Bluelightning's Avatar
Dropped my fuel tank to put my new pump in. Well the sending line fitting on the top of the fuel pump assembly snapped off like butter dropping the tank. Soooooo now I need to get my hands on an all new fuel pump assembly. FML.
Old 05-26-2016, 10:13 PM
  #486
cluelessk's Avatar
******' cars.
Old 05-26-2016, 11:30 PM
  #487
Got Bewst?
I have a line on a used one since half of it I'm throwing in the garbage anyways. I just wanna get this thing on this new turbo and E47!
Old 05-29-2016, 01:20 PM
  #488
KMO43's Avatar
I'm thinking Justin's car was around 500hp @27psi IDK what your plans are but your numbers will be up there!
Old 05-29-2016, 06:17 PM
  #489
Got Bewst?
Play it by ear. Roll around till I get bored. Then throw pistons and rods in it so I can put the turbo to good use.
Old 05-30-2016, 08:37 AM
  #490
Finally got the sway bar bushings in, what a PITA!
Old 05-30-2016, 11:46 AM
  #491
Got Bewst?
Ya I can't see that being fun lol. Did it Atleast fix your clunking issue?
Old 05-30-2016, 12:02 PM
  #492
Ya I believe it has for the most part any ways. The damn thing makes so many noises lol. Took just under 4 hours.
Old 05-30-2016, 12:14 PM
  #493
I wonder if mine are effed too. I also have a clunk. Would it clunk when you moved the steering wheel and as soon as it loads pressure it would make the noise?
Old 05-30-2016, 01:06 PM
  #494
Yes. and bumps. Bushings cost like 10$ but it is not a fun time doing it. Should do sway bar end links at the same time.
Old 05-30-2016, 01:31 PM
  #495
Was the difficulty because the bracket bolts wouldn't come off or because it's tight in there?
Old 05-30-2016, 01:42 PM
  #496
The rear bracket bolts are a bitch they are a 10 mm bolt that is inside the sub frame with a 15 mm nut on top of the sub frame but under a double layer of sheet metal that doesn't have room to put a socket of a box end wrench on need to use an open end wrench. the 10 mm side stripped on me so I slammed on a smaller socket and I ended up shaving a 15mm box end wrench on an angle and trying to bend as much of the metal flange as possible. also there are brake lines on the driver side that limit your access even more. Its designed that you should drop the sub frame. Fookin stupid.
Old 05-30-2016, 01:43 PM
  #497
Anyone want to wash and detail my car for me I got a car show at work on thursday that I have no time to prep for between training for my Tourney in 17 days and crossfit.
Old 05-30-2016, 03:10 PM
  #498
300$
Old 05-30-2016, 04:36 PM
  #499
Got Bewst?
$275
Old 05-31-2016, 09:29 AM
  #500
26 oz Bottle
Quick Reply: Manitoba SS 2016
