Manitoba SS's 2012 thread
Old May 3, 2012 | 11:38 PM
  #2076
jefferyss's Avatar
hey does anyone have any use for an apexi safc....air/fuel controller ? i have 1 im not going to end up using.
also might be looking for some 41lb injectors and there harness plugs,let me know if anyone has any
Old May 3, 2012 | 11:50 PM
  #2077
slapbetcommissioner's Avatar
Originally Posted by Garret
Sounds like lots of us are wanting to do a boost leak test. I don't have any boost leak symptoms but I still want to. We should put a boost leak kit together and meet up and do all ours in one day.
I also am planning on seafoaming this weekend before oil change.
I have heard and plan on taking out my maf, spraying the **** out of it with brake clean and then letting it sit in the sun for 10 mins.
Also Jordan I need to data log my car.
I'm definitely down for doing a boost leak test. Is brake cleaner a brand or just a type of product? Never heard of doing this..
I need an oil change soon too so I gotta do a seafoam right away.
Old May 4, 2012 | 12:39 AM
  #2078
Bluelightning's Avatar
Got Bewst?
Well I got the TVS tuned! The car pulls haaaard. I'm still getting a little bit of knock up top and don't want to sacrifice timing so I think I'm gonna drain my tank and try and stronger meth mix tomorrow.
Old May 4, 2012 | 10:07 AM
  #2079
yellow dragon's Avatar
Brake cleaner is a product its just that used to clean oil and contaminants off brake rotors you can get a can cheap at cdn tire. i just used some to clean my MAF. you can also by MAF cleaner, which is pretty much the same thing just pricier.
Originally Posted by bluelightning
well i got the tvs tuned! The car pulls haaaard. I'm still getting a little bit of knock up top and don't want to sacrifice timing so i think i'm gonna drain my tank and try and stronger meth mix tomorrow.
awesome
Last edited by yellow dragon; May 4, 2012 at 10:07 AM. Reason: Automerged Doublepost
Old May 4, 2012 | 10:19 AM
  #2080
Projekt's Avatar
You can buy MAF cleaner, ukrainian tire sells it. Its pretty much the same thing as ABS brake cleaner but not as crosive overtime.
Old May 4, 2012 | 10:22 AM
  #2081
well its the weekend woohoo!
Old May 4, 2012 | 10:24 AM
  #2082
Nice dustin glad to hear it! How's traction in third gear?
Thanks guys. Canadian tire it is!
Last edited by slapbetcommissioner; May 4, 2012 at 10:24 AM. Reason: Automerged Doublepost
Old May 4, 2012 | 10:27 AM
  #2083
Projekt's Avatar
Mass Air Flow Sensor Cleaner | Canadian Tire
its a buck 50 more then brake cleaner.
If im home this weekend bring some of that **** over hahaha
Old May 4, 2012 | 10:31 AM
  #2084
Projekt's Avatar
and sounds good garret. if i don't end up going to the lake we can do it sometime this weekend probably.
Old May 4, 2012 | 10:32 AM
  #2085
Projekt's Avatar
Also if someone can source a connector pin for our headlights that would be great, its the housing that holds the 6 pins in it, my pins and **** have corroded and i need a new one.
Old May 4, 2012 | 10:55 AM
  #2086
Got Bewst?
Old May 4, 2012 | 10:57 AM
  #2087
Got Bewst?
And I'm off to Vegas bitches!!!
Bret Michaels "Get Your Ride On" - Supercross - YouTube
Old May 4, 2012 | 11:01 AM
  #2088
soundjunky's Avatar
just popped in to see this.
since aqquiring my white Cobalt, I've come to realize that good/unmodified headlight wires are freaking tough to come by...
I believe I have one spare...
getting a complete partial harness is much easier than screwing around with them ~ which side do you need?
Old May 4, 2012 | 11:13 AM
  #2089
SLURP! DROOL!
Old May 4, 2012 | 11:26 AM
  #2090
Projekt's Avatar
Ill check when i get home, id like to say drivers side.
If you have a spare one let me know how much
Do you also happen to have a spare driver side a pillar "air bag" insert? i lost the one for Dustin and i need to get him one back
Totally forgot you had a perfectly good parts car sitting in calgary.
Also im going to Calgary XFEST to see Linkin park, have you heard anything about that festival?
Old May 4, 2012 | 11:32 AM
  #2091
Projekt's Avatar
Old May 4, 2012 | 11:42 AM
  #2092
jefferyss's Avatar
picture ? , i might have 1 for you
Old May 4, 2012 | 12:36 PM
  #2093
soundjunky's Avatar
Let me know if Jeffery has one (since that would probably be much more convenient for you).
I know I have inserts, but don't think I have a spare "Airbag" insert...
It's not officially a parts car atm...
it's a meeting with a Tech2 away from being a complete running car...
Actually I haven't..
I heard the new Linkin Park track on my recent state-side road trip ~ but didn't really care for it...
it had a "bubble-gum-electronic" feel to it...
IF that track was an anomoly, and the rest of their new album is back to having guitars, or being heavier it would bode much better for them...
I'm fairly out of touch when it comes to concerts or what not lately...
I just found out last night that I missed seeing Megadeth a couple months ago...
Old May 4, 2012 | 12:51 PM
  #2094
Projekt's Avatar
Haha okay steve ill find out with him first. let me know if you have that airbag one. im in dire need
Old May 4, 2012 | 01:23 PM
  #2095
Did you ever get your car in for warranty Jordan?
Unless your ready to go come over and seafoam in the next half hour it will be too late lol.
Old May 4, 2012 | 01:34 PM
  #2096
[QUOTE=soundjunky;6477478]Let me know if Jeffery has one (since that would probably be much more convenient for you).
There new track is not there best for sure just too long and repetitive.. However I didn't really think there last album was good but it grew on me and is now one of my favorites.
Old May 4, 2012 | 01:39 PM
  #2097
The story of the ***** interceptor.
Jordan (Projekt) bought it off a guy a few years ago
I bought it off Jordan. I found a sweet deal on dual greens with a ZZP triple pillar and sold Jordan back the pillar and gauge.*
Then he lost the cable for it... Eventually found it and sold it to Troy. Troy hated it do much he burnt it to the ground.
Old May 4, 2012 | 01:53 PM
  #2098
Projekt's Avatar
sounds pretty accurate
Old May 4, 2012 | 01:55 PM
  #2099
WPG SS/SC's Avatar
And than ya get this ******* that just had to get in for some sloppy 4th's.. Unfortunately, by the time I got to her she was rode hard and put away wet
Old May 4, 2012 | 03:33 PM
  #2100
Got Bewst?
. Well you could only read the damn thing at night it was so dim. I'd burn my car too!
