Chicago To Calgary
Chicago To Calgary
I flew to OHare last weekend drove this gorgeous 89 Formula 350 home. Car is damn near mint conditon.
Forget modding the Cobalt--nothing like RWD V8 power.
I look forward to smoking some S/C SS cars at the track
or Mustangs...whatever
heres the mods:
Engine: 365 HP ( Conservitively rated )
5.7 L98 350 Bored .30 over
Edelbrock Aluminum Vortech Heads http://www.sdparts.com/product/E6097...inderHead.aspx
SDPC Vortech TPI aluminum Intake ( http://www.sdparts.com/product/12498...Baseplate.aspx )
SLP Intake runners Port matched to plenum and intake ( http://www.slponline.com/view_produc...04&BIG=20004-1 )
Full Roller valve train with the following:
TPIS ZZ-9 Roller Cam Gross lift with 1.6 rocker is .515/.554 112deg lobe separation URL defaults to flat tappet- select next page after reaching this page to view roller cam ( http://www.tpis.com/index.php?module...t%2FValvetrain )
Crane Gold Race Narrow Body 1.6 roller rockers ( http://www.sdparts.com/product/CRA10...ockerArms.aspx )
Manley hardened push rods ( w/guide plates ) OEM GM Roller lifters
24# GM injectors, flow tested and matched
Cloyes true roller double roller timming Chain
SLP 1 3/4 ceramic Coated headers Dual Cat type ( http://www.slponline.com/view_produc...C&BIG=30005C-1 ) Picture shown is actually the single cat type as SLP doesnt sell the dual any more.
ProComp Billet aluminum computer controlled distributor. ( http://www.procompelectronics.com/Files/5.html )
Taylor 8MM wires with Center bolt style separators
Crane adjustable Fuel pressure regulator
52 MM throttle body with integrated air foil and roller bearing throttle linkage.
52 MM port matched plenum
New water pump
New motor mounts, hoses, belts
New GM sensors\relays: knock sensor, temp sender, fan control, O2 sensor, oil sender, Fuel pump relay, MAF burn off relay. New IAC motor
New Harmonic dampener
New GM Oil coolant tube assy.
Brand new alternator ( not remanufactured )
Custom ECU Prom with integrated diagnostics for recording car\ sensor data
Transmission:
Built 700R4, all new performance hard parts including "beast" sun shell, Servos, pump, boost valve, bands, bearings and clutch pack. Have reciepts
B&M Holeshot 2400 RPM Lock-up style torque converter
Rear End:
Stock 3:27 Gears
Stock Limited slip differential all bearings and seals replaced.
The drive shaft is the OEM aluminum with new HD u-joints replaced
Suspension, Steering, Chassis:
Car has WS6 package with heavy duty sway bar
2" lower intrax spring kit ( I still have the original springs )
New KYB gas Struts and rear shocks replaced with spring kit
All bushings replaced with new polyurethane bushings
Alston welded sub-frame connectors and TDS Wonder Bar front frame tie (look at the bottom of this page to see steering brace and sub-frame ties) http://www.top-downsolutions.com/ind...5a017e1d3922d4
Hotchkis Strut tower brace http://www.hawksthirdgenparts.com/in...ROD&ProdID=843
Brakes:
Rear disc brakes
New rotors, calipers, pads
Exhaust: Borla Stainless with original dual GM cats. ( Still passes emissions)
Body and Interior:
Interior is in mint condition with no rips tears burns or stains, non-smoker car. The Dash pad is in perfect condition.
All weather seals have been replaced ( including t-top with original GM kit )
Body is arrow straight. Car was stripped completely, primed, painted with two coats PPG Arctic White ( GM color) and two coats PPG clear. New GM door (bumper) moldings As I said... The car was never in an accident and no rot was present before the paint work. The old paint job was simply faded and was not a clean white as is the Arctic white. I slightly tinted the rear lights but not so bad that you will get pulled over by the law.
GTA wheels with polished lips and Charcoal Grey Centers
Undercarriage is clean and rust free
The windshield was replaced with a new one along with the surrounding molding due to some delaminating around the bottom edge of the original windshield
The rear aerowing spoiler was replaced with a lighter fiberglass OEM style replacement from G&T fiberglass painted to match.
http://www.gtfiberglass.com/PRICING.html
New GM Washer fluid and coolant over-flow containers
heres the mods:
New water pump
Transmission:
Rear End:
Stock 3:27 Gears
Brakes:
Rear disc brakes
Body and Interior:
How does it feel? Well it feels fast......but I don't like to be that...so subjective.
I only opended her up a few times (and not for a 1/4 mile either) on the way home. She has tons of low end, plus with the heads and cam, more top end then the factory TPI.
If I break 100mph I'll be happy. Not sure I can break 105 like yoiur old car....
It has 110K miles but like you said....it really does feel like brand new. And the pics do not do it justice....the paint and body are even better in person.
The car is mint. Nicely done. There is a bit of seep at the rear diff pinion. It looks nice lowered but I know where you are coming from wanting it up a bit.I did the OPI on it.How did you find it?
autotrader.com
Gotta love US cars....so cheap. Hope she got some looks at the dealership
I know Dave...the service writter from years back at Stampede Pontiac...now I know 2 people
there's quite a few of us on here that work at ****. me for one, criz78 is another and of course spaz
