Dtp2008!!!
#203
i would stay with 18's, and even on yours you would still have to get the ECM recalibrated for the bigger tire size but you shouldn't have any clearance issues. if you go bigger then you run into possible clearance issues.
#204
go with a 18 x 7.5... u wont have any clearance issues, and u wont need a refalsh if u get the right size tire...
im running 18 x 7.5 with 225/45ZR18 and my speedo is only .5% off... not enought o worry about..
#205
ya i knew it would be off by a small amount just couldn't remember how much. to some people it would bother them lol. im with you .5% isn't enough to worry about.
#206
Well my new header and downpipe are on order, also I am getting a newer set of new projectors because these ones kept fogging up......and to make it that much better I am now getting the headlights with the BLACK housings!!
I am buying the AEM Wideband from Spaz, so all that I have left to get is the three pod A-pillar and the HP Tune from neo01 in the spring....and this car should be running beautifully!!!
#212
Hey spaz...I am sure I asked you this before....but what kind of lowering springs do you have? And did you find any problem with scraping and the firmness of the ride?
#213
Canuck motorsports springs. Fit awesome ride ok no rubbing or problems whatsoever. I would recommend these springs to anyone. cost $200 bucks if you order them off ebay.
#214
How much of a drop is it?
Also....do you have a spring compressor??
#215
I have one at work , you don't need a spring compresor to do them. it drops the car about 1.0 to 1.5" i think there rear doesn't go as low as the sportlnes check my gallery for pics.
#216
im running canuck motorsports springs.. dropped my car about 2 - 2.5 inches all the way around
bought right off of canuckmotorsports.com for 182.50 SHIPPED!!
i bought a set before i even had the car in my posession..
i believe i am goin to be the first turbo ion in calgary baha!! buying a turbo kit jan 15th
#217
You don't need a spring compressor for the front struts?!?!?
I prefer to have the rear up a little higher then the sportlines.
Any problems with the OEM struts?
#218
I haven't had any problems. The new springs are short enough you can push them down to get them on.As for taking them off be careful. I do have a compressor at work but I have done lots without it.
#221
its always a good idea to get an alignment check whenever you do anything to modify the front suspension. in the case of lowering springs its not a huge deal but still recommended
#222
you guys want mods... here is a mod!!!
AEM Wideband
EGT Gauge
Boost / Vac Gauge
Turbo Manifold
TD04l-13T Turbo (i have another one for a backup i'll include)
Downpipe
Intercooler Piping
Apexi Twin Chamber BOV
FMIC
(4) 38# injectors High Imp *
Oil Lines
Tapped Oil Pan
Fittings
Turbonetics Evolution Wastegate with 5,7,9 psi springs (9psi is installed)
Extra intercooler piping.
AEM Wideband
EGT Gauge
Boost / Vac Gauge
Turbo Manifold
Downpipe
Intercooler Piping
FMIC
Oil Lines
Tapped Oil Pan
Fittings
