For Sale FS: Brazen GXP 47,000 Miles
I'm in the process of building a house and was told that I need to reduce my debt to qualify for my loan so I must put my Gxp up for sale because I need to free up some cash. I’m selling my Brazen (orange) 2008 Pontiac Gxp convertible. The car is a currently has 47,000 and I’m asking $17,000 for it. With all of the parts below included. This roadster comes fully loaded with leather bucket seats, power options, a black convertible top. It features sport tuned suspension and sport metallic pedals, 18" chrome wheels, high performance audio system with AM/FM, OnStar, XM, . Bluetooth is included as well as steering wheel radio controls. I have every receipt for everything and anything done on this vehicle. I have alot more pictures available if needed and also have every receipt for the car. I'm located in Jacksonville fl and you can send me a pm with any questions
The following maintence and mods has been done:
Ignition switch recall was done
Replaced pcv valve
Brand new convertible top replaced
Coolant flush
K&N cold air intake
DDM charge tubes powder coated black with upgraded clamps
DDM Backbone & Probeam
DDM Oil catch can power coated black
DDM Power steering location kit
DDM Black cross bay brace
Aem methanol injection & will include 3 bottles of methanol (Can be removed if buyer doesn’t want)
It has had been tuned by DDM
Powder coated black valve cover and intake manifold
Jpm short shifter with black boot
Solo Performance and hi flow cat
Dakota Digital Gauges Boost, Exhaust Gas temp, Fuel Pressure, Oil Temp/ Oil Pressure
Pioneer cd player with usb/OnStar/XM
2009 black headlights
Shorty Antenna
I have the following parts sitting at DDM all brand new and still in the box waiting to be installed that will go along with the sale:
Bc coilovers extenders for rear ($40)
DDM Intercooler ($700)
Ferrea Valves($350)
ZZP Stage 2 Cams ($999.99)
Werks 5th injector Kit powder coated black ($959.99)
Neutral Balance shafts ($269.99)
Gm Water pump ($291.50)
Werks Springs ($299.99)
Parts Description Blocks Universal 2.0L
* timing chain tensioner 54.94
* Rear Main Seal 31.42
* Timing cover gasket 26.48
* Main Bolts 90.40
* Girdle Bolts 83.10
GM Thermostat 60.38
Alternator - A/C Belt 20.00
P/S Belt 14.00
* Main Bearings 37.56
* Head Gasket 46.85
timing chain 125.96
Timing Chain guide top between cam gears 20.03
Timing Chain guide slack side 19.18
Timing Chain guide tension side 51.11
K1 Rods 450.00
Wiseco Pistons - slick Sides, wrist pins, rings, locks (suggested) 86.5mm bore
695.00
ARP Head Studs 135.00
Spark plugs 42.88
Valve Cover Gasket 2.0L 30.38
There is a total of around of $6000.00 in brand new parts.
Replaced pcv valve
Coolant flush
K&N cold air intake
Shorty Antenna
Ferrea Valves($350)
* Main Bolts 90.40
GM Thermostat 60.38
P/S Belt 14.00
* Head Gasket 46.85
timing chain 125.96
K1 Rods 450.00
695.00
Spark plugs 42.88
