DevilsOwn Alcohol Injection DevilsOwn Alcohol Injection is a Supporting Vendor of cobaltss.net
Contact: devilsown
Nozzle flow chart comparing 3 pumps
Old Sep 1, 2010 | 11:19 AM
devilsown's Avatar
Below is a chart that compares the nozzle flow using the three most commonly used pumps by methanol injection companies. This chart is intended to show you how as nozzle size is increased the pressure of the system decreases.
On the nozzle pressure chart, the dashed line on the 250psi pump shows how increasing the adjuster on the built in by pass effects pressure. Most pumps have this built in, but as you can see, it will only effect the output on nozzle sizes 3 and smaller.
The 150psi and 250psi pumps both flow 1gpm and the 220psi flows at 1.8gpm.
Supercharged06SS
Dec 11, 2022 04:47 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
