Dezod Motorsports Dezod Motorsports Is a Supporting Vendor of CobaltSS.net
contacts: Dezod
New GReddy Informeter
Old Aug 21, 2006 | 12:21 PM
Dezod's Avatar
New Item that is universal and provides some good information is the GReddy Informeter. It comes in black or silver, and provides the following info:
Read Up to 25 pieces of information:
Communicate with the factory ECU to red up to Channels. Like: Speedometer, RPM, Water Temp, Ignition Timing, Injector Rate, Intake Air Temperature., Fuel Temp., Air Flow Voltage, Intake Manifold Press., O2 Sensor Voltage, A/F, Battery Voltage, Throttle Position. WGV, ATF Temp., EGR Temp., Gear Position, 4WD ratio, Exhaust Temp.
Simple Plug & Play Installation:
Just Plug-Iin the appropriate cable into your vehicle's Diagnostic port, under the dash (ISO 14230 or old Nissan fault diagnosis connector) And for vehicles which use OBD2 ports, a cigarette lighter plug powers up the unit.
Easy to see Color LCD screen:
By adopting a color screen, monitoring numerous values is easy. Key warning point values, are highlighted to call attention to them.
Monitor, Record adn Playback:
Not only does it monitor, but it Records and Playbacks Info. Data log up to 6 pieces of information simultanelusly. Recording resolution can be selected from fine to smoothing.
We have a limited amount of these in stock in each color, and as an exclusive to Cobalt SS board, we will upgrade you to free 3 day shipping!
http://dezod.com/pd_greddy_intelligent.cfm
Old Aug 21, 2006 | 12:23 PM
DWK5150's Avatar
I was actually looking at that the other day.
Old Aug 21, 2006 | 12:25 PM
Dezod's Avatar
It does quite a bit of nice data. Several other vehicle owners like some of the functions like air intake temp and such.
Old Aug 24, 2006 | 10:15 AM
Dezod's Avatar
Silver left.........
Old Aug 24, 2006 | 10:27 AM
CTCOBALTSSS's Avatar
Does it measure boost or HP?
Old Aug 28, 2006 | 10:23 AM
Dezod's Avatar
I was told by GReddy it will for a stock turbo car.
BTW, only silver left.
o3nisoaso3
Feb 12, 2008 06:14 PM
SlowBalt_06
Dec 4, 2007 10:47 AM
GSoccer24
Aug 9, 2007 04:47 PM
leviticus88
Feb 3, 2007 08:44 AM
victoryredss
Feb 14, 2006 02:55 PM
