Drag Racing Kindle Racing and Dalcorp Racing
15" wheels on SS SC
Old Nov 13, 2011 | 09:21 AM
mongorat427's Avatar
15" wheels on SS SC
Has anyone managed to get 15" wheels on SS SC Brakes by grinding the Calipers ? Cant find a thread with our lame search engine
Old Nov 13, 2011 | 09:34 AM
Powell Race Parts's Avatar
just bolt on some base LS calipers and rotors, cheaper and easier than taking a grinding wheel to decent (single piston?) LSJ calipers lol
Old Nov 13, 2011 | 09:45 AM
ATLsilverSS's Avatar
it has been done on an hhr ss without the brembo option. i think the guy ground 1/8th off to clear. now i have no idea what brakes those are tho
Old Nov 13, 2011 | 10:47 AM
What about the spindle. I thought it was different on the base model.
Old Nov 13, 2011 | 10:51 AM
I think they might be the same as LSJ or G5GT
Old Nov 15, 2011 | 07:42 PM
2006RedCobaltSS's Avatar
Ralliarst (sp?) I believe did it.
Old Nov 15, 2011 | 07:47 PM
mofofernando's Avatar
this guy is running 15s
just take out the spaces
http://www . gm sport compact . net/...and-TWO-117mph...
Old Nov 15, 2011 | 08:45 PM
troyss's Avatar
I did a couple months ago
So did cmiller
Have to grind the caliper down to get them to fit.
Old Nov 15, 2011 | 10:14 PM
So did cmiller
Yep thats what I did. Now I have to pick out a set of wheels to fit my 5x114.3 bolt pattern. and tires
PROXES DRAG SLICK
25.0X9.0-15 TOYO DRAG SLICK N or
M&H 24.5x8.5x15
Old Nov 15, 2011 | 11:37 PM
ULWizSS's Avatar
took about 15 minutes to shave each side. But yes LSJ here on 15 with M& H Slicks
Old Nov 16, 2011 | 08:20 AM
cmiller8006's Avatar
kosi k1 wheels are your best bet, light as **** and good price.
Old Nov 16, 2011 | 09:57 AM
Cant find anyone selling them. I want 8" wide if possible
Old Nov 16, 2011 | 10:33 AM
ULWizSS's Avatar
i went with the verde protocols and the M & H Slicks. Zrated is on the same setup as well.
Believe we shaved 6 pounds per wheel as well from stock.
Old Nov 16, 2011 | 10:40 AM
zrated89's Avatar
yea and from the M&H engineers themselves that is the best combination for our setup. I ran a 12.1@116mph and trapped 117. But since you have a different lug pattern im sure you have more options
Old Nov 16, 2011 | 05:46 PM
Found these
Rota Wheels Slipstream Gold 15X8.0 5X114.3 +40MM Off Set 5 Lug (4 lug in the picture)
Old Nov 16, 2011 | 07:47 PM
zrated89's Avatar
rotas are usually pretty light too
Old Nov 16, 2011 | 07:53 PM
EXsoccer1921's Avatar
if you want a 15x8 go with a +26 (5.5" backspacing) stock backspacing is 5.7" for an sc wheel. so the 15x8 5.5" will allow for a slightly wider tire, say a 255/50/15 (25.1"x10")
its also a very common backspacing on 15" drag wheels
Old Nov 16, 2011 | 07:56 PM
14.2lbs
Billet Specialties RS035806555N Billet Specialties Street Lite Race Wheels
Old Dec 30, 2011 | 12:26 PM
DarkChild's Avatar
I had seen a picture somewhere of someone that had done it. I might make a how to if I do this as well.
Old Jun 14, 2012 | 07:04 AM
FrossB's Avatar
Thread Killer
To further bump this thread, is there any "stock" type wheels that anybody has tried? steelies, random oem wheels, etc. Im lookin for some 15x7 or 15x6 wheels to run some 225 slicks/radials. I am also 5x114.3 bolt pattern
Old Jun 14, 2012 | 08:26 AM
I found these on Summit raceings Website. They have a 5.50 backspacing which is close to my 18x8 Drag wheels so they should work if your LSJ calipers are prepped right. (A little grinding needed to run 15s)
Summit Racing SUM-571-5866PS - Summit RacingŽ Warrior R/T Polished Wheels
$119.95
Wheel, Warrior R/T, Aluminum, Polished, 15 in. x 8 in., 5 x 4.50 in. Bolt Circle, 5.50 in. Backspace, Each
Old Jun 14, 2012 | 08:31 AM
FrossB's Avatar
Thread Killer
if i were looking at the 15x7 and they only have a 4" backspacing...that would basically be the same amount of clearance correct? I do have spacers that i could run if needed
Old Jun 14, 2012 | 08:37 AM
FrossB's Avatar
Thread Killer
is that ground down? (im viewing from my phone)
Old Jun 14, 2012 | 08:42 AM
Yes theres a little casting hump that needs smoothed out to run 15s
Measure your wheel to be sure.
Last edited by mongorat427; Jun 14, 2012 at 08:42 AM. Reason: Automerged Doublepost
