2008 NHRA rulebook
1 Post
2008 NHRA rulebook
I was rereading this years rulebook and happened to glance at a rule that would affect many of the Cobalts here that race.
Section 4 - general Regulations Page 63
"Fuel/Air
Ambient-temperature air only; cooling or otherwise changing the conditions of the intake air is prohibited. Spraying of intake with any artificial spray or coolant prohibited." - 2008 NHRA Rulebook
This means the use of Meth injection.
I was looking into using Meth injection, but as it seems I'll only use it off track when I'm running only premium. I'll just have to run race fuel maybe with alcohol to compensate since I'll be running high compression pistons.
Hope this helps everyone.
Also the rulebook does say Methane can be used, as a fuel, but has to be properly sealed so moisture in the air may not contaminate the Methane since can rapidly absorb moisture. And if methane is contaminated you risk the chance of being disqualified.
"Fuel/Air
You might want to clarify for the T&T drivers. I know nothing about NHRA rules, only SCCA, but I know any sort of SB can get confusing for the casual competitor.
1) Is this something that is a no exceptions - i.e. If you're running at an NHRA sanctioned track, meth is not permitted. There are certain things that are prohibited at any auto-x - nitrous is the most universal example. Show up with a nitrous-equipped car and you'll be asked to leave and may be asked to not come back depending on whether or not you should have known better.
or
2) Is this something that only affects a competition run? i.e. You run this at an actual competitive event and you'll be DQ'd. Sort of like running an illegal mod in SCCA. Your times are scratched and you're told run the proper class, remove the mod, run a different car, or don't come back. However, if this is something that you only run seasonally in the winter and just haven't changed it yet or if you bring a set of non-stock wheels to a test and tune and run in the wrong class, no one really cares.
I think the vast majority of the people here go to the open lanes/test and tune nights where this wouldn't apply if it's a competition-only thing. I'd hate to see someone not do a mod they want to do for fear they'd be turned away from a non-competition track day when the rule has no bearing. However, if it's a universal thing as in you can't run it at all on any NHRA track at any time, then yeah, it's something people should be aware of.
or
1 Post
T&T and Street nights are not affected, unless sanctioned by the NHRA event. This is general guidelines on only race classes. Sorry figured it'd be self explanatory.
The Meth injection on T&T and Street nights would be dependent on track rules, since those are usually held by the track, and are not official race days.
Again this rulebook is based on Sanctioned Race days, so the track probably will allow it. Can't hurt to check.
Nitrous injection is a different section, and is allowed in certain classes, but remember Nitrous oxide introduces more oxygen into the cylinder, it is not used for cooling.
LOL, I just brought it up because I used to help with registration for auto-x...NOTHING is EVER self-explainatory. For every rule you find to be straight forward, it will confuzzle at least 25% of everyone else. If you find a rule to be up to interpretation, it will confuzzle 75% of everyone else. Was trying to save 500 people from coming in the thread freakin out thinking they'd get kicked out of a T&T night for meth injection.
So, for clarification, it is still okay for those that compete in a Street Legal Series to run Water/Meth injection or nitrous but not okay for those in a E.T. series? Just want to make sure since I've already had a rough time with tech at the driver's meeting last week concerning the 3rd hose that releases pressure from the top of the surge tanks. They said I would have to install some sort of a catch can, then they said since it is OEM I will be okay without one.
Yes... street legal classes are an acception... to a point.
You still have to pass a tech inspection... which means you need a separate reservoir for the w/m, approved line and fittings, and a suitable pump.
Most kits offer an acceptable pump... but very few offer acceptable lines.
About the catch can.... NHRA techs love you if you put a can on every drain and over flow on your car... it's just one less car to worry about spilling fluids on the track.
1 Post
Yea catch cans not only save the track, but it keeps your car clean when you blow a ring haha. And yes I KNOW Nitrous Oxide can be used for cooling, I work with chemicals Freezing pipes, but this is saying you cannot cool the air artificially, which includes spraying the Intercooler with Nitrous Oxide.
And yes this is a rulebook set up for actual points racing. While many tracks still use many of the rules for T&T and street nights. Really all the safety ones, there not to worried about you spraying your Intake lol.
I race in NHRA in the superstock class. Basicaly the rule pertains to class racers, when they have a "heads up race: (wich = fastest car wins) instead of a normal bracket race,What alot of guys have been doing is spraying the intake manifold and radiator with CO2 or upsidedown "air in a can" freon and other chemicals to get the motor super cooled, it was becoming a problem because people were using cryo coolers and whatnot and hiding the bottlesi guess their were saftey coserns. If a tech guy calls a street car out on it hes a douche bag. If you install your water meth corectly i doubt they would even notice it
09BlkCrusader
09-09-2015 04:47 PM
