Crappy 1/4 times
Crappy 1/4 times
Well my first time out to the strip and the car honestly ran like ****. my best run of the night was a 2.2 60ft running 15.1 @ 92. 92mph? wtf is that? I dont know if it was too humid or what but 92mph trap speed is not what i expected. Every run, of like 10, except the one mentioned above was a 93mph trap speed with times from 15.2-15.5 depending on the launch. 60fts ranged from 2.2-2.4. Only bogged on the 1-2 upshift once so thats not the problem and I never once hit the 2nd gear redline.
My first time at the track was a few weeks ago. On my first run I got a 15.1, by my last run I was trapping at 98 mph with a 14.6 and 2.3 60ft. I felt I was leaving some on the track because I was only launching at 1.5k rpm. The next time I go I am launching at 2.5 rpm to see if I can get a 14.1
The temperature probably had a lot to do with it. Also you must shift at redline , if you bog the shift that 15.1 is the best you will see.
What were your reaction times ?
Once again, didnt bog the 1-2 upshift and i was shifting at the last second before it would hit the rev limiter. If I launched any harder than 2k i would get bad wheel hop.
On that 15.1 my reaction was .15
The track itself might be ****, you were saying something about evo's and gto's running mid 14's than 15.2 might not be that bad it just might be a slow track. I have seen the left lane be very fast and the right lane be slow as *****.
to be honest 14.8-15.2 is where most of the stock cobalts are running first time out.
these cars are pretty picky. Id say give it some seat time and some better conditions and youll see those numbers drop.
the people running low 14s arent doing it first time out.
