Is this good?
So i'm coming from work today & I decided to go down the 1 road by my house that nobody uses so I decided to use the interceptor gauge for the 1/4 mile. (Its a flat road with no curves or hills.) So I go for run #1 & got a 14.15 @103mph w/ no wheel spin. I thought to myself with all the mods I've done I CAN do better. I need to shift faster. Much faster. So I drive slowly at the actual speed limit of 40mph to let the clutch cool off & I'm back to where I started. Run #2 went ok. I got a 13.85 @ 106mph with some wheel spin. I know that throws the the gauge off a little but I still was not fully satisfied so I went on run #3. With my head now in racing mode & only looking at the road in front of me I took off with barely nothing if ANY wheel spin. I shifted from 1st to 2nd extremly fast & at the perfect time. 2nd to 3rd it was completly floored. same with 3rd to 4th. I got 13.45 @ 107mph. Anyways I got home and thought about my excitment for the day & was thinking
Wow. I got that good of a time having me be about 100lbs overweight (I weigh 244lbs you do the math). And I also have 2 Solo-baric L5's in 1 box with a 1600 watt amp 3.0 farad cap & 25 lb box of random **** in my trunk, but the thing that kills me is I am still on my stock clutch & flywheel. I just received my spec stage 3 clutch & fidanza flywheel thru the mail today & haven't even installed them yet & this is the times I'm getting without them + 175 extra lbs.
Anyways my friend got a 2003 Mustang GT but hes getting a 4:10 rear end with flowmaster exhaust & my other friend has got a caddy seville w/ the northstar v8 & we're going up to are each putting up $100 at the dragstrip. Think I'll win
My mods are:
GM stage 2 w/ 2.8" pulley
Injen CAI
XTC downpipe
Cat eliminated
Pacesetter 2.5" exhaust
Putting on tommorow:
Spec Stage 3 clutch
Fidanza 8.5lb flywheel
Any commnts are welcome.
My mods are:
Injen CAI
XTC downpipe
Cat eliminated
Spec Stage 3 clutch
hope you brought your wallet.
those times will no tbe the same at the track. traction is way different, and the light makes a difference. it's not just you leaving it has to do with reaction time and 60 fts too. RWD will own you at the light
Reaction time doesn't matter in a regular 1/4 mile race. Once you leave the line is when the time starts. I watched an older lady literally sit at the light for 6 seconds and still run a low 13 second 1/4 mile. Reaction time matters in bracket racing sometimes though
Originally Posted by kobaltking2589
I'm sorry this may sound like a dumb Q but how much will the 4:10 rear end add in hp.
That gearing is more for quarter mile runs.
It doesn't necessarily add hp, but it will make him more of a beast off the line then let's say at 80mph...
Originally Posted by Tomtwtwtw
Yeah, I don't think the Caddy will be a problem, but the Mustang with gears could very well beat you.
I have owned 3 mustangs to 5.0 with 410 gears and man do they pull hard. But if you can get boost quickly without a lot of wheel spin which is the worst thing about our cars I think you can get him. I have about the same moods you do and I would say my cobalt would give my stangs a good ride for the money especially from a roll but obviously thats not the case. Stock 5.0 runs in the 14's now the new 4.6 may be a bit faster but I dont know. My old stangs would run in the 12's my cobalt will not run that but from a 30mph roll off I think the balt is right there.
