helpfull track tips
helpfull track tips
So i took my 07 ss/sc to the track last night and didn't do nearly as well as I though i would!!! I didnt do any weight reduction or anything but on ran 14.959. I spun so incredable much that it was even funny!!! With my mods i should be hitting around 14 flat. This was my first track day but does anyone have any hints to pick up my 1/4. BTW it was fairly cold and the track was a little slippery!!!
tips for you is when in 1st gear only use half throttle or a little more. i don't understand people who spin the tires up and think there going fast. it slows you down so much it's not even funny. going half throttle you feel like your going slow but your going to be going faster trust me. noise isn't everything
A "perfect" launch will have just a little spin as the tires are pulling you forward. You will never develope the throttle control nessisary to do this if you start off with the wheels spinning though. Even at the track I have to be careful when I go to full throttle in first to avoid breaking lose.
thats what im getting since i got wheel hop. but i wouldnt get them if your just peeling out.
Btw burning tires never helps, i always get a bit jumpy off the line because i get impatient and go full throttle a bit early,
http://www.youtube.com/watch?v=bSYrHasqfEM
that is what it nets you. Mind you the track was drizzled on a couple times but still isnt fun.
once i got gm stage 2 and 2.8 pulley on i ran 13.8
i think people just need to practice nailing the times they should then slowly upgrade. otherwise if you take a driver you can't get 14.6 or better with a stock ss/sc and give them power they will just get a worse time if not never ever get lower than a 14. those are my feelings towards this situation. if it is that hard then put stock pulley on with gm stage 2 and just keep practicing until you can nail the times this car should be hitting from the factory. then start dropping pullies and learn how to deal with wheel hop (let off the gas) or wheel spin (slip the clutch more or don't go full throttle)
just my 2cents
