Losing weight without losing creature comforts?
Given the cobalt is already pretty light, mine weighed sub 3k with driver and over 3/4 tank. Yet i still want to drop more weight if possible. At the same time i like my seats, and a/c.
Things like lighter wheels and CF trunk/hood are always a easy way to drop weight. As are the standard removal of spare/jack.
Am i missing any easy items that won't be missed? Just brainstorming here, no idea is a bad one.
I've tried bringing up this topic before, but usually get flamed by people saying "just make your car faster instead".
Lighter wheels: Enkie PF01s or OZ Aleggritas
Lighter battery: Braille 21lb battery (saves about 20lbs, works all year) or Braille 15lb battery (saves 25lbs, only good for the spring/summer/fall)
CF hood & trunk: The reason I haven't done this yet is because CF parts cost so much compared to a $150 battery that saves just as much weight.
Remove spare tire and jack
Get rid of the lip and lower side trim kits.
wingless
dump the pad under the trunk. And under the hood if your car has one.
catless/mufflerless/side dump ahead of the wheels.
Anything you can do with unsprung weight helps a lot. Never get on a twisty road? sell that hardcore bar.
lower grill insert. gone
potentially some of the plastic surround on the radiator, though that might harm cooling.
see ya later floor mats. and any insulation under the carpets.
empty that stuff collector that we call a glove compartment.
wingless
1) some of them are really good at drag racing.
1a) so you're saying don't even bother trying to improve?
1b) just because you don't think it's fun doesn't meed we should. go check your ego somewhere else
2) you want to drag extra weight through the corners and down the straights between them?
2a) weight is weight, and there is no need for extra be it straight or around a corner.
The question is what are you willing to sacrifice? Not sure if these parts are avalible but this is what i can get/have for my evo.
Lighter rims
2 piece rotors (perhaps even a small brake kit if you are set on drag racing)
racing seats
a/c delete
light weight battery
coilovers
gut the interior including sound deadening, air bags, rear seats...pretty much everything that the driver doesnt need.
stearing wheel
lightweight flywheel
remove or replace with lightweight front/rear crash beams.
stfu. You do realise that you can drop weight and go do corners alot better as well right?
Lighter rims
racing seats
a/c delete
coilovers
stearing wheel
Then a diet is the answer. Seriously unless you are willing to sacrifice comfort, you wont be able to drop enough to notice a difference.
Also not sure if ford does any other type of racing but you gotta think about where you are removing the weight. It can really **** up your balance on the car. Which is why people recommend not only trying to keep the weight balanced but to get corner balanced when you get coilovers.
Why did you delete your other comment? I don't know why you keep referring to Camaro's, they are ******* pigs and most that I have seen running at the track have not ran 11's. If the guy wants to take his Cobalt to the track and run it then so be it. Do I personally think that a Cobalt is made for the strip? No, but I don't come in threads bashing the dude because that's what he wants to do with HIS car.
Never did I bash him, but he will also realize is takes a lot of cash to drop weight on a car and whoever told him more power was 100% correct.
Didn't want to derail the thread either, but some people could use a search button more effectively as well.
Not worth my time arguing, camaro's are pigs, but are easily capable of faster times for half the price of any built cobalt made.
bah go to the track with a cobalt... so what if it's front wheel drive? so what if it can't compete with a RWD setup on the 60ft?
90% of people at the track don't even know that the car is capable of beating alot of cars there. it may not be AS fast as some...but it will definately impress people even if it isn't as fast.. it's still a very quick car for what it is in the 1/4... FWD or not.
anyone with a brain knows FWD doesn't compare to RWD in a 1/4 mile scenario. and when a FWD car CAN keep up with a good chunk of hte RWD cars there it gets alot of respect to those who have a true appreciation of cars in general.
This is exactly how every weight thread talking about small weight losses turns out. Some jackass comes into the thread saying "Why bother, INSERT RANDOM CAR HERE is faster in the 1/4 mi just buy one of those. Cobalts aren't made for drag racing. Weight doesn't matter on a road course. Blah blah more stupidity blah.". m33pm33p proves my point exactly.
It does not cost a lot of money to drop a little weight on these cars. Even a little weight makes a difference, anyone who has taken physics should know that. F=ma. 1% less mass has to be made up with acceleration since the force to the wheels stays the same.
Cobalt daddies the man
It is hard to remove weight and keep creature comforts. Or keep it cheap. I mean sure u can buy a lightweight flywheep but those save u what five lbs? And cost like 300 bucks.
Best options im seeing is removing backseat/rear carpets when possible. Lightweight battery (best to take more weight out of the back for proper transfer) and removing spare tire, replace with can of fislx a flat. Remove trunk floor panel and ugly hood blanket. Looks better without the hood blanket anyway.
as said above, un-sprung weight is your worst enemy. the rule of thumb is for every 1Lb of unsprung wieght saved is like 3 lbs of sprung weight.
do you use your back seat? you can pull that out and put in a piece of fiberboard with some black clotch to cover it and make it look somewhat finished, wingless, all of your trunk stuff, except the battery! im sure there is more.
if you think drag racing a cobalt is pointless, whats witht eh 1/4 mile time in your sig? **** off
AMS AC Delete - $110
AMS Lightweight Battery - $220
AMS Lightweight crossmember - $220
Lightweight driveshaft - $800
Racing seats - $3000
ACT Streetlite Flywheel - $340
PF01 rims - $1000 (used)
2 piece rotors - $1550
turbo back exhaust - $1200 (used)
So $8440 for approx 192lbs (33lbs rotational mass). Thats just on parts that cost me money that ill be doing this summer. Thats not including stripping the interior, trunk(spare tire and tools) and **** like that. As well as out of that 192lbs, parts gave me more hp and others gave me better handling (well in theory it all did since less weight gives better handling)
Edit: also forgot to add in lightweight crash beams. For some reason the jap's version of the evo the crash beams and brackets are a total of 8lbs lighter.
