Question About ET and MPH
so ive been going to the track often to get better at racing and get my et down. sunday i went to the track for a bracket and ended up running some decent times...my question is when i ran a 14.9 @ 95 mph, how did next run be a 14.8 @ 93mph?? check out the time slips...
at 2:04 pm:
.881
2.272
6.368
9.681
73.83
12.482
14.968
95.52
at 2:38 pm:
.635
2.323
6.354
9.632
74.39
12.409
14.892
93.84
and if you notice at the 1/8th my 14.8 mph was faster than my 14.9 mph, but by the time i got the 1/4 i was 2 mph slower but ran a faster et...can anyone tell me why that is, and is it something i'm doing?? or is more of the weather and the conditions at that time??
at 2:04 pm:
.881
2.272
6.368
9.681
73.83
12.482
14.968
95.52
at 2:38 pm:
.635
2.323
6.354
9.632
74.39
12.409
14.892
93.84
Seems obvious to me but you're right could be 100 factors. Your ET is faster mostly due to a quicker 60FT and 330. I believe why your MPH went down at the end is due to lower RPMS at the high end which would show that sometime AFTER 330 & around(likely just after 1/8 th track) you either shifter too soon in the powerband going from 2nd to 3rd...OR you just shifted a bit slower allowing the RPM's to drop which kills MPH. Possibly some wheel spin from 2nd to 3rd but I doubt it! Being that you were so far ahead at the beginning of the run, lower ET still but yes...@ a lower MPH.
my 2 cents
Best of luck
Brandon
my 2 cents
Best of luck
Brandon
Well considering you cut a better .60ft on the slower of the two runs it could be that your 1-2 and 2-3 shifts were substantially quicker on your second run..enough to make around a tenth of a difference. Of course there are TONS of other factors involved i.e wind speed and direction, temperature difference, just to name a few.
