Drag Racing Kindle Racing and Dalcorp Racing
Questions on launching and racing???
Old Nov 9, 2014 | 04:53 PM
SSxTc0825's Avatar
Hey guys. I just had a few questions about what not to do in drag racing, etc. If I was to go to the track and stage up, would dumping the clutch snap the transaxle? If so, what's best to prevent that? As far as launching goes, smoothly starting at like 5500 should be sufficient? Any mods I should do before going to make good times, mph, etc? My 03 Eclipse was slow as s**t so my 06 SS/SC should definitely surpass it. I just wanna work on the Balt before the track opens up next spring.
And I swear I searched the drag racing forum before I created this thread!
Old Nov 9, 2014 | 05:05 PM
Bass_Waves's Avatar
practice practice practice. Practice makes perfection. Take your time and find the sweet spot and launch it then. start off by taking off like its a red-light. then get on it a bit. and keep raising it. if the car hops. let go of the gas. simple.
Old Nov 9, 2014 | 05:37 PM
slapbetcommissioner's Avatar
I wouldn't launch at 5500rpm. You will never get traction unless your running slicks or radials. It will be wheel hop city and that's when you run the risk of breaking your trans or axles.
Old Nov 9, 2014 | 05:41 PM
Originally Posted by SSxTc0825
spring.
Lies!!
https://www.cobaltss.net/forums/drag-racing-52/art-drag-racing-285907/
Old Nov 10, 2014 | 06:22 AM
SSxTc0825's Avatar
Thanks guys. Yeah I was trying it out last night lol I went through Hermitage and was kinda toying with the launching a bit, nothing crazy though. Yet did race a Mazdaspeed3 though. He had me on launch but I caught up to him. We started a 35 roll and I managed to stay in front until a car pulled out in front of me
So slicks and maybe a CAI, catback, DP, header, and possibly a tune?
Old Nov 10, 2014 | 06:43 AM
These will help
ZZPerformance - ZZP LSJ Axles #ZZ-LSJAXLE
Old Nov 10, 2014 | 07:42 AM
SSxTc0825's Avatar
Originally Posted by ECaulk
Will the S1s work? Or should I upgrade to stage 2? My car is stock and will be probably until next spring when I get my yearly bonus. Then I'll get the ZZP S3 and other necessary assorted upgrades
Old Nov 10, 2014 | 08:28 AM
phatnackySS's Avatar
On street tires or drag radials 1800 to 2000rpm feather the clutch out , like pulling away from a light aggressively.
the only time you you want to launch that high is on slicks. These cars have more than enough low end tq.
Old Nov 10, 2014 | 08:35 AM
blueLNFftw's Avatar
He probably brake boosted on you then, unless you are bone stock and not GMS2.
Roll race from 40-45mph in second. Work on your 2-3 shift. Roll racing is where the LSJ will shine with the m62.
Dig race I launch it about 3k and feather the throttle to keep as much traction as I can. Then again, I also have a 50% boost cut in first gear so my car does not make boost until the higher RPM of first gear.
Old Nov 10, 2014 | 08:39 AM
blueLNFftw's Avatar
Skip the axles.
Buy Napa Gold axles if you end up snapping one.
LNF Shift Tower Bracket to clean up your shift slop.
OTTP Stage 2 Rotated Mounts
Ingalls Torque Dampener for the TAM
The axles on these cars are pretty strong. I never broke a CV shaft on my car. I did break the cup on the passenger side, but it was my fault for cutting a hard turn mid burn out and the CV got pissed. Even then the cup was welded and CV rebuilt.
Old Nov 10, 2014 | 08:56 AM
toyo proxie r888's and practice man. then move on with the power mods.
keep the rear suspension stiff too, keep the car light, and be nimble and quick shifting.
Old Nov 10, 2014 | 11:28 AM
SSxTc0825's Avatar
I figured they had pretty good low end torque. Thanks for the tip though. I'll have to remember to try that. Now is that first? Or 2nd?
Im not sure but I cAn almost guarantee that my car is 99% stock. It has an AFR and a volt meter but other than that I have no idea. Bought last week at a dealership. I've noticed the M62 does wonders in a roll race
Skip the axles.
Thanks man. I heard the axles weren't too resilient when it comes to that stuff. But I have no idea. I'm new
Ok cool. Thanks. So like rear strut brace, stiffer springs, etc?
Old Nov 10, 2014 | 11:58 AM
blueLNFftw's Avatar
Look at the pulley on the SC.
Is it one big nut or 4-5 small bolts holding it on?
Old Nov 10, 2014 | 12:42 PM
SSxTc0825's Avatar
Look at the pulley on the SC. Is it one big nut or 4-5 small bolts holding it on?
I will when I get off shift tonight. I'm guessing that'll establish whether its stock or not?
Old Nov 10, 2014 | 12:45 PM
blueLNFftw's Avatar
Yup
Old Nov 10, 2014 | 12:47 PM
SSxTc0825's Avatar
Yup
Ok cool. Anything else I should look for?
Old Nov 10, 2014 | 05:48 PM
SSxTc0825's Avatar
Hey I looked it has 4 smaller bolts on the SC pulley. I was also looking at the small model tag underneath it and I think it's a stage 2 GMPP
Old Nov 15, 2014 | 02:46 PM
NikeTapia3's Avatar
So yeah not stock has a smaller sc pulley which means it could have more work into it. Or maybe just that pulley !
Jan 12, 2016 12:01 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
maliki778
Oct 1, 2015 07:39 PM
SSLOW06
Oct 1, 2015 07:21 PM
