Drag Racing Kindle Racing and Dalcorp Racing
snapping an axel
Old Jul 21, 2009 | 01:26 PM
wtpcobaltss's Avatar
snapping an axel
what r the chances of snapping an axel at the track with stock axels and my mods in my sig
Old Jul 21, 2009 | 01:36 PM
Gestapo007's Avatar
HIGHLY LIKEY especially since you have no mods to reduce/eliminate wheel hop.
Old Jul 21, 2009 | 01:38 PM
Fast Black SS's Avatar
friends has only a stage 2 kit and he broke his. Invest in better axels.
Old Jul 21, 2009 | 01:44 PM
Mindrot's Avatar
What axel?
Old Jul 21, 2009 | 04:25 PM
sput's Avatar
axle.
Old Jul 21, 2009 | 04:41 PM
arkkornkid's Avatar
go ahead and order Driveshaft Shop axles and have them on stand-by. If you get lucky and don't break the oe's, good....but chances are you're going to in the near future, so at least you won't have to wait on shipping. At least it's an easy fix.
Old Jul 21, 2009 | 09:26 PM
ok well went to the track and didnt snap 1 so im happy
Old Jul 21, 2009 | 09:29 PM
THRcobalt07's Avatar
its called preloading!!!! granted I don't have many mods, but I've been to the track countless times and as long as i preload the suspension I have had no problems. I have noticed that I will wheel hop if I dont preload enough or if I dont launch high enough
Old Jul 21, 2009 | 09:33 PM
06G85's Avatar
How do you preload?
Old Jul 21, 2009 | 09:36 PM
zrated89's Avatar
when your at the tree hold the brake a let the clutch out slow when you feel the motor and trans shift you know you have all the slack out of the drive trane.
Old Jul 21, 2009 | 09:40 PM
ya pretty much what he said. here's what i do: pull up the e-brake as high as you can while holding the button down, rev it up to what you wanna launch at and start to disengage the clutch, you will feel the car crouch, once you feel its crouched enough slam down the e-brake feather the throttle and depending how much you disengaged the clutch feather that too. Sometimes when i preload the clutch is pretty much disengaged completely by the time i throw down the e-brake. but the big thing is feathering the throttle
Old Jul 25, 2009 | 07:13 PM
Snakes709's Avatar
so instead of snapping an axle u risk snapping your ebrake cable or the actual brake or ******* your clutch up...nice!
Old Jul 26, 2009 | 02:27 PM
09WhiteSS's Avatar
hahahaha
Old Jul 26, 2009 | 02:31 PM
sick06cobalt's Avatar
been there and seen it happen.... its very easy... i had to push the car back to the parking lot lol
Old Jul 26, 2009 | 03:29 PM
ya only if your a *******..i messed up my clutch a while back, but its because I didn't know how to exactly do it. If you do it how your supposed to you will be fine. Id rather have a car with clutch that MIGHT slip than a car that is immobile because the axle is snapped. But you are completely right buddy...you're a genius and ppl who preload are idiots :facepalm:
Old Jul 26, 2009 | 04:04 PM
LTZ XsTaT1c's Avatar
or you can get motor mounts,stronger axles and not have to do all kinds of crazy ****. tada!!!!
Old Jul 26, 2009 | 04:08 PM
Ill still preload with all that business..better 60's. Just think about this, if you have the suspension already preloaded you dont waste that extra time in the transfer of energy to the wheels. If you don't your car has to transfer that energy before you start moving
Old Jul 26, 2009 | 04:18 PM
my car cant even get wheel hop, I bought the car and the clutch went out and I demolished it at the track to finish it off horibly lol heres a vid though of the car actually holding up to a trans am with no clutch lol
Old Jul 26, 2009 | 04:24 PM
nice, all im sayin is to each his own, but this is what works for me
Old Jul 26, 2009 | 04:28 PM
RooTBeeR's Avatar
dude, i broke mine with poly trans mounts, and an intake...not even tuned
shitty gm tiny ass axles...
Old Jul 26, 2009 | 04:49 PM
Gestapo007's Avatar
i like your idea. i gotta try it. Id probobly start with the E-brake b4 i try to heel toe the brake and clutch. wheel hop seems to not be so bad in the SS/TC but I also have lower motor mounts so I dont seem to run into that problem so much. But preloading to help 60's is a plus
Old Jul 26, 2009 | 06:34 PM
ya the lnf has the better axles..gm should have put out a recall for these shitty ass axles on the lsj but oh well. now they are offering a wheel hop kit with mounts and the lnf axles.
but preloading for better 60's does make sense to me, if it doesn't for some then idk what else to say
Old Jul 26, 2009 | 07:25 PM
RooTBeeR's Avatar
the LNF axles are actually biogger than the stg. 2 axels
Old Jul 26, 2009 | 11:43 PM
ya thats why they offer that kit with the lnf axles
Old Jul 26, 2009 | 11:48 PM
RooTBeeR's Avatar
who does???
