someone explain this...
so stock, i ran a 9.2s at 76mph 1/8 mile awhile back. my 60' ft was a 2.1.
now i have a 2.85" pulley and last night the best 60' ft i could manage was a 2.34. the best 1/8 mile time i got was a 9.44s at 77mph. what the hell is going on? im doing everything the same as when i ran the 9.2. do i not have the right setup with the new pulley or something? could it be major traction problems? clutch? what can i do to fix ths? i can feel that the pulley makes a big difference, but im not seeing it in my numbers...
ok i know where to get the injectors from, but where do i get the reflash from, intense???
BTW thanks guys, i figured it was something like this. my second gear felt really weak in the higher RPMs.
How much boost you seeing???
you can get a MBC and clamp the boost down a pound or 2 say your running 17psi clamp it to 16 or 15.5 to richin up the A/F you would prob make more HP up top with it then running 17psi lean
OMG....You're running a 2.8 without anything.....You are running lean man..Trust me...Go to the Intense Racing website. Order their fuel injectors with maf translator. Also try to order either a wideband a/f ratio gauge or get your car dyno tuned. That should richen the car up.
CTCOBALTSSS is talking about the GM stage reflashes. You could get them but they are a tad expensive.
almcphee
Sep 23, 2015 09:55 AM
