Street tire fun.
Rev limiter is set at 6700, I will not rev to 7000 any more untill I get either a whole built head or new stronger valve springs. I have broke two roller follows on the same valve. Replaced the spring once and its broke again. I am know running with the broke roller till either I get the head or I have to get a head do to a fucked head lol. Not intended to be mean it just pisses me off.
Oh it will go lol. I was going to tell you to turn down the torque in first but couldnt find you. You getting a good launch and you can tell at about 4000-4500 you start blowing the tires off, even on your good runs. Did you happen to weigh your car? Mine was 2980 with me in it. And I had the seats in it and all. I was suprized.
Last edited by cmiller8006; May 22, 2010 at 11:00 PM. Reason: Automerged Doublepost
first run i had torque set at 45 through most of the range ending at 64 percent. it felt weak. turned it up to 51 and ending at 67 percent. most runs were good. launching at 2700-3000 car was mostly sticking. last run launched at 4000. held for a second, then just let loose. had second set at 100 percent through the whole range. seems to buck and bog on the 1-2 shift. set back to 60 and progressed up to 100. didn;t seem to make much difference. lol. was getting discouraged. best run was 13.17 @ 108. forgot to weigh the car. i had the upper back seats out, and the trunk empty.
shift at 6500 1-2. shift 6500 2-3. go through the traps in third at 6700-6800.
So those deflated footballs don't get ruined just sitting inside your springs all that time? Seems like they'd get ruined pretty quick. Is the ride just too stiff leaving them inflated all the time or what?
