Track Times :/
Track Times :/
Tried out the slicks for the first time. Turbo was only tuned on 21psi as my fpr was bad when I got it tuned so I just turned up the boost a little bit and logged it.
My best 60' was just a 1.9 but I only ran 14psi in 1st gear and didn't wot shift 1/2nd so that killed my 60' and 1/8. I know it had mid 11's in it even as it sat but I wanted an 11 for now, hit it with out breaking so I called it quits. haha
Low Boost D65 Srt-4 - YouTube
But really, considering a lot of ET's here (or in general) for a few simple mods a 13.3 in a V6 pony is geat. Few more trips and another mod or two he will see 12's.
Haha, I wish a bottom/trans build was cheap. Have you seen the prices of a quality input shaft alone? $$
1/8 was pretty bad with 1st gear boost and the 1-2 shift.
7.8 @ 95
(not making excuses, as everybody's traps got a little slower) but a 15-20mph headwind developed later in the day. The run before that was a nasty 2.1 60' I trapped right at 97mph in the 1/8 but for whatever reason my boost box cut it to gate pressure in 4th and it ended in a 12.3 @ 114
7.8 @ 95
7.8 @ 95
7.8 @ 95
Thanks
I had a pass that was right at 97mph. The 7.8 @ 95 was with a nasty 1.9 60'. Though fwiw I was only running 14psi in 1st gear. A lot of variables.
If my arf's are looking ok, I'm going back the 17 and want to try 20/29/29/29 and wot shift every gear. We will see.
Btw, happen to have any pics of how you set up your limiting chains?
Stage 2
Yeah..first time at the 1/4 and on slicks so I was a retard and stayed in the waterbox for my short burn out. I'm going to try to get a better launch next time. Wot shift 1-2nd (aswell as make the other wot shifts faster it was on 150) ..and turn the boost up a little bit.
