Track Video
Track Video
Best run of 13.19 @ 108.86 with **** 60' times. Going to replace my plugs, install a new clutch, and get up to Cecil. Should easily get 12's up that way.
And my slip:
And my slip:
That mph is good for 12's if you can get your 60' down into the 1.9-2.0 range. sounds like it dead hooked and just bogged. Launch higher next time and you'll get your 12 sec slip
I was using launch control. Had it set to 60% for the 13.1, or around 2900rpms. Bumped it to 3600rpms and spun too much. A dude covered the track in coolant so they had to clean her up. I went out for one more run after that and cut a 2 flat 60', but the clutch slipped while NLSing 1-2 and I threw misfire codes and lost power. I called it a day after that.
My best slip from the track last night I had the right lane.
Hahaha I couldn't drive for **** for whatever reason.
I blame it on the new tune n clutch not to mention the long ass winter in ohio.
Spun all the way thru first n second.
Driver mod needed.
