Tuned and Track Results
It's pretty amazing how you picked up 26mph in the back half, but I don't expect to pick up that much. I'd be happy with 23/24. But I look to trap about 85-87 or better in the 1/8th. I don't think that's unreasonable to ask from what I'm adding and doing.
I'm adding, 2.9, slight porting on the intake manifold, header, catless dp, ditching the intercooler filler neck for a reservoir that I'll fill with ice at the track, dual pass, and a custom tune by area47.
I'd like to run consistent 12's. I don't think that'll be too much of a problem.
there may be a few things that I left out that I'm not thinking of off the top of my head.
eh, we'll see. I think it will be faster than 12.9. I will be dissappointed if that's all I get. With the added power, I should be able to cut sub 2.0 60ft.'s easily. 1.8 doesn't seem too far fetched. And with a trap speed close to 110, I can see the car going 12.5/6 easily.
well, I could have easily gotten 13.3/4 out of the car as it sits. That's with stock pulley, header, dp. I'm adding pulley, header, catless dp, more cooling, and an even better tune than before. Realistic gains I would say would be 5+mph gain in the 1/8th and about 8+mph gain in the quarter. That should be plenty to hit high 7's to 8.0 in the 1/8th and mid 12's. I don't think power will be an issue for me anymore.
What afr/timing do you plan to run?
there is more power to be had. 12.5 is **** for afr.
you have two options.
A. run the meth mix i run, and pick up power. or B. richen it up.
both will require a retune.
*walks to corner and cries now*
Last edited by BriantheLion26; Aug 19, 2008 at 05:53 PM. Reason: Automerged Doublepost
25.5° is too much? I just had it like that for at the track. DD I have it at 11.6 and 21-22° if I remember correctly.
Hopefully I can get this out of you Area... how would you set my car up for track days? Just AFR and timing, I doubt you will give out more than that.
Im not Area but, my tune that netted me the most hp and trq, i went with a ramping afr from 11.5 low end building up to a 12.2-12.3 afr and 24 degrees of timing. My car started to lose power at anything above 25*.
Damn nice back half of the 1320.
I never tried messing with ramping up the AFR or timing at all. I just had it set to command 11.9 in PE (getting 11.7-11.9 actual) and 25-26 degrees through the whole run.
ssssssshhhhhhhhhhhhhhhhh
Lol Area!!
Please, knowing you, you have some other insane method to make a **** ton of power on anything you tune. And what upsets me more is that you dont share!! LOL
I have to dissect any dyno sheets you post to even get anytyhing close to an idea on how YOU tuned the damn thing, lol.
Lol Area!!
So what does the master think of ramping up the AFR instead of commanding a certain afr all the way through the rpm range in pe?
Matter of fact i dont think i ever thanks Area for that....
Very doubtful, you havent seen my old tunes, lol.
As for AFR ramping is concerned i think the formula was rich best trq, lean best hp. That and dissecting dynos from anyone with decent power numbers, you can actually see the transition from when they start leaning the car up. Thats how i came to that idea. But maybe Area will chime in. I would say im a DECENT tuner at best. Area, Al, Dan, And 06black i would prolly consider top tier, lol. Theres a few others...but im sure you know all im talking about.
Anything above 12.0 AFR is begging to roast your pistons and for the minute gain you might get from it , its hardly worth a new motor
Also water should always be 50% of your mixture, everyone knows that running stupid **** like 90% meth and 10% water is just adding fuel and its taking away from the purpose of what water injection is for and thats to be a knock suppressant which allows you to run more timing. Every single vendor that makes the kits will tell you that. Also Methanol has a very very low flash point, so if you want to set your engine on fire, go right ahead.
I think too many people put FAR too much trust in one individual on this site whose suggestions are borderline dangerous to both the longevity of the motor and a fire hazard instead of actually researching and finding the truth themselves.
lol!
