Warren's 1/4mi Results
Ok imma scan a few in once I get around to it in the morn.
Car had the 18's on w/ KDW's, had roughly 100lbs of school supplies. another 100lbs+ for all my sub box and amp's. Skies were partly cloudy. Temp 46F. And the best result was!!!!! A 16.1. R/T .154 60' 2.551 1/8m 10.488 MPH 69.29 1/4m 16.119 MPH 86.97 Something I desperately need is traction. This 16.1 was achieved on the edge of stock ls wheel hop. on a couple previous runs i took it just a tad too far into the powerband and hopped my a$$ through first gear. results from taking that bit too far pushed me into 16.3-4. So my question is this.....should I go with the reversed mount's from OTT, or should I say screw it and get my 2.4 mani w/ retune. I figure either would break me into the 15 second barrier. :) |
get nitrous, run 13s lol
Sounds like you need some traction mods, but also a driver mod. ;)
With those mods you should already be running mid 15's easily. That 2.5 60' is killing you. Get that down to a 2.2 and you'll be well into the 15's. If it makes you feel any better, I ran a 2.44 16.0 with all bolts on, but untuned. I'm an auto though, with you being a standard there's no reason why you shouldn't have a better 60'. Good luck. |
ya 60' is really bad.I have shitty ass tires and pulled a 2.2 60'.Drop your press a bit.Thats how I got my 15.40.
Also what are you launching at?I launch at 2500 |
i say get the mounts first, if you do the intake your still gonna have wheel hop, and thats how things break.
Originally Posted by FASTL61
(Post 3599483)
Also what are you launching at?I launch at 2500 Were u running on the stock steelies? On my fastest run, i held it at about 2800rpm and had the tires to that point where they are screaming but not quite losing all traction through about 4500rpm(know what i mean?) and chirped second. considering it was my first time racing at the track in like 5 years I'm happy. i think i may just use some money i got coming in on the 2.4 mani/tune AND reversed mounts. :) |
sorry to thread jack but im going to the track this summer for the first time what kind of times do u guys think i ll run considering those few mods i got?everyone keeps asking me what my times are so im just trying to get an estimate
I was running my 16" wheels in my pic gallery with bald ass tires.I lowered my pressure to 25psi then did a nice 2nd gear burnout to clean them off.The track i go to uses alot of VHT(traction aid sprayed on track)and if you dont burnout then you have lots of rocks stuck to your tires.
Wheel hop is cause by improper launching techniques. aka dumping the clutch instead of slipping.
Originally Posted by warrenb213
(Post 3599360)
oh another thing youll wanna do is no lift shift(kepp the gas floored and just pop the clutch to shift)If youve never done this youll have to practice so you can get quick at it.Just from NLS i went from 16.18 down to 15.6. Then ported my stock exhaust manifold went catless and now im at 15.40 with stock exhaust manifold(ported)modified downpipe(catless)SS/SC resonator with full catback and a custom intake.NLS FTW
Originally Posted by slowswap
(Post 3600509)
does this make sense or am i off by a lot?
(Post 3600502)
(Post 3600556)
Lots of things to do this summer. New minimum mods for summer list: Reversed Mounts 2.4 Mani/RE-tune WOT-Box w/ NLS option only perhaps with those 3 extra things in the cobalt, of course with extra practice at the track, will see consistent low-mid 15's?
Originally Posted by scott allen
(Post 3600524)
those are some good times i had a 04 cavi,with the 2.2 ecotec and with a auto,with a rk sport header and rk sport cai ,and a catback ran a 10.26 at 69.96 mph in the 1/8 mile .
Originally Posted by Sentry
(Post 3599472)
With those mods you should already be running mid 15's easily. That 2.5 60' is killing you. Get that down to a 2.2 and you'll be well into the 15's. If it makes you feel any better, I ran a 2.44 16.0 with all bolts on, but untuned. I'm an auto though, with you being a standard there's no reason why you shouldn't have a better 60'. Good luck. The whole logic behind it makes sense. A typical shift for most is about .5 second(no NLS, but aspirated). I'm sure I'm faster on the shift than average but without being full throttle I'm still into that half second range). With an NLS shift not only are u still full throttle but your slammin the gears probably down to about the .2-.3 second range I'd imagine. |
Ya thats how I went through my first trans lol.Toasted 2nd gear but Ive been beatin the hell out of the new trans and I cant break it haha.I powershift every gear.2nd gear makes the biggest diff when powershifting.I would try it once at the track.One time wont hurt it.Mine blew up cause i kept doing it all the time,run after run after run.But like I said the new trans is holding up quite well now:)
(Post 3600643)
i r hoping to run 14s soon :D i was at 15.4 with stock tires, mounts, all that, just a cai, header, dp, lsj exhaust, and tune...slip the clutch out, NLS and concentrate lolol
dammmn,
well hey NWAE in the next couple months I'll be coming up to Auburn area to see Vince about a new dyno tune for my car with the 2.4 mani installed. Perhaps I'll find some extra money for the lsj downpipe and a gmpp or custom exhaust. Depends how much money I'll come across. all i know is i at least wanna be hitting me low low 15's by end of summer. lol |
ouch. You need driver mod :lol: I never got mine to a 1/4 track before i sold it but with just an injen CAI, vibrant header & dp, and gmpp cat back i ran consistant 10.1s and some 10.0X runs in the 1/8th. If i didn't use my driver mod it was up around 10.5, get your 60ft down and your time should be alot better :twothumbs
*Moved to Drag Racing*
Get rid of the 18s for the track, the bigger the sidewall, the less chance of wheel hop.
The weight reduction would also help your times. You should be able to pull a better 60ft then that, but dropping the rim size, and using a larger sidewall tire, and of course less tire pressure will really help you out. Kevin |
(Post 3601974)
dammmn,
well hey NWAE in the next couple months I'll be coming up to Auburn area to see Vince about a new dyno tune for my car with the 2.4 mani installed. Perhaps I'll find some extra money for the lsj downpipe and a gmpp or custom exhaust. Depends how much money I'll come across. all i know is i at least wanna be hitting me low low 15's by end of summer. lol if you need help installing we can do it at my house :) and i have a couch to crash on if you need too |
Originally Posted by senior_brown
(Post 3599377)
a 16.1 out of a LS is pretty remarkable.
Back when my 2.4SS was stock (and a auto), I was runnin 16.1/16.3's. |
Originally Posted by Turbo06Sedan
(Post 3649165)
get youre 60' down!!!!! the 18's also do alot more than u think...put youre steelies back on and try again...YOU CAN DO IT!!!!
Dont be going to the track with 100+ lbs worth of stereo equipment in the car, that's just plain stupidity.
same for the school stuff..... dump these two items and you have mid to high 15's end of story.... |
