Drag Racing Kindle Racing and Dalcorp Racing
Went to Cordova tonight
Old May 2, 2009 | 01:34 AM
mkriebs's Avatar
And... Well, I immediately met my goal for the night. The first run of the night was picture perfect. I ran a 13.2 at 108. VERY quick. I was not expecting it to be that great, and it was quite the pleasant surprise. Needless to say, that was the best run of the night from me. The other runs weren't bad, but they could have been better. There was an accident where a kiddie dragster flipped, and that took a long while to take care of, and in that time, the track lost all its heat, and deteriorated quick.
I think i have the launch control pretty well dialed in for these tires. they really aren't good at all, and once I get some stickier tires, I think i can raise it a bit and do better in the 60' times. All in all, it was good night. No broken parts, and it was fun. I met my goal, and that's very pleasing.
Oh yeah... I am completely stock with the exception of a tune, motor mounts, trans mounts, and sportlines. Running stock tires at 28psi, launch control set at 3000, rev limit to 7200, and NLS shifting 2-3 shift (not 1-2 due to wheel spin).
Here is the time slip:
Old May 2, 2009 | 01:36 AM
07saggycobalt's Avatar
where you residing in illinois?
im close to peoria
Old May 2, 2009 | 01:38 AM
mkriebs's Avatar
I am from Sterling. Cordova is by the Quad cities (in case you were wondering).
Old May 14, 2009 | 12:23 AM
how were you launching that night? rpms?
Old May 14, 2009 | 01:56 AM
mkriebs's Avatar
I set my launch control to 3000, and was letting the clutch out pretty quick. Wasn't NLS'ing the 1-2 punch, but was the 2-3 shift.
I did have a better trap this past time around, which is very surprising, because I lowered my rev limiter back to 6500 from 7000. This past time i trapped at 110mph, but still only got a 13.2. I think thats about all the car has in the state its in right now.
Old May 19, 2009 | 02:13 AM
outlaw ss's Avatar
Wish my 05 had launch control!! I will be @ Cordova for Midnight Mayhem this week. I hope to back up or beat my G-Tech run 13.80 @ 108. I think if I had launch control I'd just blow the tires away anyway!! On the G-Tech I spun through 2nd gear so I may be faster if I can hook. Plus I didn't take anything out of the car, including a passenger.
Old May 19, 2009 | 02:29 AM
mkriebs's Avatar
Not bad... what are your mods? I am going to try to make it to midnight mayhem, but I may not... I am not sure if I will be there yet.
Old May 19, 2009 | 01:20 PM
outlaw ss's Avatar
I have the GM Stage 2. I have a ZZP 3inch DP w/ cat into a 2.5 inch Magna-flow without the resonator. I have the stock air box cut up with a few extra holes in it with a replacement K&N. I cut the stock intake tube and replaced the part from the throttle body to the headlight. I am also toying with an icebox for the aftercooler fluid. I have drilled and slotted rotors and Konig Hotswaps with Nitto Invos. I replaced the stock splitter with a carbon fiber piece. You may see me around Davenport I'm the Yellow SS with the 4% window tint.
Old May 19, 2009 | 01:30 PM
mkriebs's Avatar
Nice... I might be there, i might not... but I don't make it down to Davenport very often...
Old May 20, 2009 | 01:35 AM
outlaw ss's Avatar
Davenport was kinda nuts this spring. Lot's of street racing. I gotta work Friday til midnight. I will be there around 1o am. If you show look me up.
Old May 20, 2009 | 01:42 AM
mkriebs's Avatar
I'll be there! I'll be the lowered black ss/tc with the red pinstripe and the LNFperformance sticker in the rear windows. Likely gonna be the one on the laptop all night, lol. Should be the one running 13.2's, lol... hopefully... if I haven't broke yet.
I'll send ya a PM...
Old May 23, 2009 | 05:16 PM
Blur.fx's Avatar
Pave It All...
Pretty sure you're the car I saw go 13.0 @ 110mph at the end of the test and tune last night... Nice run!
Old May 24, 2009 | 03:03 AM
mkriebs's Avatar
Thanks. If it was a Cobalt, and it was running 13.0, then that was me. I must say, I am absolutely surprised what this car can do. I didn't think I would be knocking so hard on the 12's door with just a tune.
Old May 24, 2009 | 10:27 AM
Blur.fx's Avatar
Pave It All...
Some of the bracket racing regulars say Cordova is a tenth or two slow so maybe you're already in the 12s on a better track.
Old May 24, 2009 | 01:51 PM
mkriebs's Avatar
Yeah, I am going to go to Rt66 in Joliet sometime in July and see how that goes... might have to head to Byron as well just to see.
Old May 29, 2009 | 12:10 PM
wantedSS/TC's Avatar
question, did you set launch control for 3,000 or did you feather the clutch to 3,000.
I hate launch control bc it launches you so high!
If you DID set launch control to 3,000 on the computer, how do you do it???
Old May 29, 2009 | 01:19 PM
mkriebs's Avatar
I did it through HPTuners.
Old May 29, 2009 | 01:20 PM
ahhh, good ol' HPTuners!!
That'll be my choice for a tune!!
Old May 29, 2009 | 04:24 PM
jabbott's Avatar
What rpm did you shift at?
Old May 29, 2009 | 04:48 PM
mkriebs's Avatar
6600 and ran it through 7 k in 3rd.
Old Jun 5, 2009 | 07:32 AM
jabbott's Avatar
Where is the table for launch control in hp tuners?
brickloaf
Show & Shine
56
Jun 18, 2019 12:51 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
OrangeK
Sep 20, 2015 03:02 AM
Supercharged06SS
Aug 28, 2015 10:50 AM
