WRX Wheel Horsepower????
Yeah, I have the 2.0. I'm still stuck on the mantra I got from the Cobalt when it comes to tuning. If you tune for summer then you won't be rich enough for winter and pop goes the motor. And of course I don't feel the need to butcher my interior with gauges if I don't have to. I like the clean factory look.
And if I got a pro-tune I would want to know exactly what was going on. I think the Cobb OTS maps are generally safe enough that you don't need to monitor it and worry, but a pro-tune would give me pause. Something about it, it worry's me.
Well you have that completly backwards. If you run the off the self map you dont know what the hells going on because its not made specifically for your car. Look on nasioc there are tons of threads saying ran way to rich or way to lean. Not to mention you trusting something thats saying you running 22% idc. You get it protune you know exactly what you afr's are as well as powerband and they will not change due to weather. A protune is much safer then the ots map by far, ask any good tuner. Not to mention most ots stage 2 sti's dont put more then 275 whp with a powerband thats all over the place and most tunned ones are right around 300whp. Seriously you have less to worry about if anything.
Well i kind of made the cobb maps look bad and thats not really the case. The cobb ots maps arnt bad and 90% of the time everything is fine. Its just the protune with a good tuner will make it seem like you have a completly different beast. And having an 06 sti you could see like 50wtq over the ots map which i dont have to tell you, is sick. I dont want to talk you into something you dont feel comfortable with, its just somthing you should really look into because its worth it.
DANRICKARD
Oct 1, 2015 12:08 AM
