2.0 flywheel question
ok so the biggest issue with bolting up a f35 tranny to a 2.4 seems to be that you cant find a six bolt hole flywheel for the 2.4 that is big enough for the f35 tranny correct?
Well how big in diameter is the 2.0 flywheel? Zzp has a clutch kit for the 2.4 that features a 9.5 inch flywheel and the stock size is 9 inch....so why not call up zzp and order that flywheel and a 2.0 clutch and the f35 tranny? I see no flaws in this idea but anyones input is welcome:) |
Overall size isn't the issue, the clutch mounting patterns are different. You'd have to use a complete 2.4L clutch setup or complete 2.0L setup, can't use one flywheel with the other clutch. Transmission spline is not the same IIRC.
