2.0 flywheel question
Old Aug 6, 2011 | 11:57 AM
etnies's Avatar
ok so the biggest issue with bolting up a f35 tranny to a 2.4 seems to be that you cant find a six bolt hole flywheel for the 2.4 that is big enough for the f35 tranny correct?
Well how big in diameter is the 2.0 flywheel?
Zzp has a clutch kit for the 2.4 that features a 9.5 inch flywheel and the stock size is 9 inch....so why not call up zzp and order that flywheel and a 2.0 clutch and the f35 tranny?
I see no flaws in this idea but anyones input is welcome
Old Aug 8, 2011 | 05:06 PM
ItalianJoe1's Avatar
Overall size isn't the issue, the clutch mounting patterns are different. You'd have to use a complete 2.4L clutch setup or complete 2.0L setup, can't use one flywheel with the other clutch. Transmission spline is not the same IIRC.
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
Sep 28, 2015 12:51 PM
jas09ss
Sep 26, 2015 01:06 PM
