2008 Saab F40 info
This is the info sheet for the F40 used in the 2008 6 speed Saab 93. This is the one used in the ZZP conversion. Also used in 07 and 09 This is the close ratio trans
2008 GME Germany F40 ( MU9 ) Type: transverse front wheel drive, six-speed manual transaxle Maximum engine torque: 245 lb-ft ( 333 Nm) Maximum gearbox torque: 295 lb-ft ( 400 Nm ) Gear ratios: MU9 First: 3.769 Second: 2.040 Third: 1.365 Fourth: 1.048 Fifth: 0.846 Sixth: 0.707 Reverse: 3.538 Final Drive Ratio: 3.55 Maximum validated gross vehicle weight: 3527 lb ( 1600 kg ) Case material: aluminum Center distance: 197 mm Fluid type: Castrol BOT 0063 Transmission weight: wet: 56 kg ( 123.5 lb ) Fluid capacity (approximate): 3.1L / 3.27 qt. ( dry ) Power take off: no Applications: Saab 9-3 06 F40 MT2 Gear Ratios (like this: 1st, 2nd,...6th IE 3.77 = 3.77:1) Both have a 3.55 Final Drive 3.77, 2.04, 1.32, 0.95, 0.76, 0.62 07-08 F40 MU9: 3.77, 2.04, 1.37, 1.05, 0.85, 0.71 |
Thank you sir. Once I grenade the transmission out of warranty I'll probably go this route. :lol:
How could I swap my auto for this?
you can't
(Post 7073659)
you can't
Okay here's the best answer you'll probably get.
Yes possible, can install it yourself and have your car down for a few weeks? Why does everyone say not to do it, you could get a F23 trans cobalt switch all your parts over then sell your now back to stock cobalt and be able to pay off most of the price of the new car with the sell. It's way easier and will work instead of going through all the unknowns that you'll be the first one ever solving and thus on your own. So you're aware the F23 is actually stronger than a F35 trans and you can even add add a LSD but will need a new clutch and eventually axles. I'm very happy I spent extra time looking for a manual and paid a bit extra. |
(Post 7073668)
Yes possible, can install it yourself and have your car down for a few weeks? Why does everyone say not to do it, you could get a F23 trans cobalt switch all your parts over then sell your now back to stock cobalt and be able to pay off most of the price of the new car with the sell. So you're aware the F23 is actually stronger than a F35 trans and you can even add add a LSD but will need a new clutch and eventually axles. |
And I Know someone has swap auto for manual even if it was just to the f23
Originally Posted by cobalt523
(Post 7073670)
I don't know why people keep saying to sell the car, I spent way too much time, money, blood, sweat and tears on this car and I'm not selling lol and I heard the f35 can hold more TQ, and I can pic up a f35 from an 09 ss/tc for 175$
I am making almost 400 lb ft of torque and over 460 horsepower at the crank and my 4.05 F35 is just fine... |
(Post 7073664)
Go away, nobody likes you
(Post 7073677)
tc has a 3.82 final drive. SC trans is a 4.05 final drive. Lower gear has way better acceleration. I am making almost 400 lb ft of torque and over 460 horsepower at the crank and my 4.05 F35 is just fine... |
(Post 7073674)
Originally Posted by Killa SS
(Post 7077517)
Im mak8ng 461whp and 383 wtq just blew 3rd in my stock f35 lasy weekend
F23 is a under rated to hell . Getrag says its only good for 180 ft/lbs. but that must refer to stick clutch. Local cavalier puts 600 ft lbs of torque through his
(Post 7077615)
what were you doing when it happened? |
sorry to hear that man, I am taking my car to the dyno on monday. I am trying to get my BRFPS tuned up for a few more whp. Gonna stop at 440 whp. I am trying to keep my car in great daily driving condition and still maintain my WOT power. The car right now is a beast and so much fun to drive. I am not going to lean on her to much harder.
(Post 7078929)
(Post 7078925)
Driving. Smooth shift to 3rd. Got in it and that was her last pull for third. It just free revved. I checked other gears as I slowed to stop and check shit out under neath. Just lost 3rd :(
Originally Posted by mongorat427
(Post 7079552)
Whats your plans now ? Theres not any parts available to rebuild unless you have a donor trans. Is it LSD ? |
(Post 7079596)
Jeff. We talked on the phone a few days ago. Its not lsd. Im just waiting on zzp. I d9nt need my car right now. I have my bike
it should be noted that you CANNOT buy parts for these transmission no matter what version you look up. and btw it is also used in 2003-2004 saab's, and there are v6 saabs running 400+ hp and 450+ torque.
Why would you need parts. You can buy the trans for 300 and up. Theres new ones on carpart for as low as 400
(Post 7081696)
(Post 7081696)
im currently swaping auto to manual with a 2004 f40 transmission and the bad syncro is my biggest fear about using that transmission.
(Post 7081727)
We dont want the pre 2007 trans tho do we? Too long of gears right?
I search to find deals plus I deal with yards and warehouses over and over so I get stuff they cant sell cheep
