2008 Saab F40 info
Old 05-28-2013, 07:52 PM
mongorat427's Avatar
2008 Saab F40 info
This is the info sheet for the F40 used in the 2008 6 speed Saab 93. This is the one used in the ZZP conversion. Also used in 07 and 09 This is the close ratio trans
2008 GME Germany F40 ( MU9 )
Type: transverse front wheel drive, six-speed manual transaxle
Maximum engine torque: 245 lb-ft ( 333 Nm)
Maximum gearbox torque: 295 lb-ft ( 400 Nm )
Gear ratios: MU9
First: 3.769
Second: 2.040
Third: 1.365
Fourth: 1.048
Fifth: 0.846
Sixth: 0.707
Reverse: 3.538
Final Drive Ratio: 3.55
Maximum validated gross vehicle weight: 3527 lb ( 1600 kg )
Case material: aluminum
Center distance: 197 mm
Fluid type: Castrol BOT 0063
Transmission weight: wet: 56 kg ( 123.5 lb )
Fluid capacity (approximate): 3.1L / 3.27 qt. ( dry )
Power take off: no
Applications: Saab 9-3
06 F40 MT2 Gear Ratios (like this: 1st, 2nd,...6th IE 3.77 = 3.77:1) Both have a 3.55 Final Drive
3.77, 2.04, 1.32, 0.95, 0.76, 0.62
07-08 F40 MU9:
3.77, 2.04, 1.37, 1.05, 0.85, 0.71
Old 05-28-2013, 08:21 PM
YelloEye's Avatar
Thank you sir. Once I grenade the transmission out of warranty I'll probably go this route.
Old 06-17-2013, 12:32 AM
cobalt523's Avatar
How could I swap my auto for this?
Old 06-17-2013, 12:46 AM
redcobalt07's Avatar
you can't
Old 06-17-2013, 12:56 AM
cobalt523's Avatar
you can't
Go away, nobody likes you
Old 06-17-2013, 01:05 AM
andrewcarr1993's Avatar
Okay here's the best answer you'll probably get.
Yes possible, can install it yourself and have your car down for a few weeks?
Why does everyone say not to do it, you could get a F23 trans cobalt switch all your parts over then sell your now back to stock cobalt and be able to pay off most of the price of the new car with the sell. It's way easier and will work instead of going through all the unknowns that you'll be the first one ever solving and thus on your own.
So you're aware the F23 is actually stronger than a F35 trans and you can even add add a LSD but will need a new clutch and eventually axles. I'm very happy I spent extra time looking for a manual and paid a bit extra.
Old 06-17-2013, 01:15 AM
cobalt523's Avatar
I don't know why people keep saying to sell the car, I spent way too much time, money, blood, sweat and tears on this car and I'm not selling lol and I heard the f35 can hold more TQ, and I can pic up a f35 from an 09 ss/tc for 175$
Old 06-17-2013, 01:17 AM
cobalt523's Avatar
And I Know someone has swap auto for manual even if it was just to the f23
Old 06-17-2013, 01:20 AM
c130aviator's Avatar
tc has a 3.82 final drive. SC trans is a 4.05 final drive. Lower gear has way better acceleration.
I am making almost 400 lb ft of torque and over 460 horsepower at the crank and my 4.05 F35 is just fine...
Old 06-17-2013, 01:40 AM
Truth hurts little buddy.
Old 06-20-2013, 09:05 PM
Killa SS's Avatar
Im mak8ng 461whp and 383 wtq just blew 3rd in my stock f35 lasy weekend
Old 06-20-2013, 09:25 PM
Who has done this?
Old 06-20-2013, 10:35 PM
what were you doing when it happened?
Old 06-20-2013, 11:43 PM
Ceeker's Avatar
F23 is a under rated to hell . Getrag says its only good for 180 ft/lbs. but that must refer to stick clutch. Local cavalier puts 600 ft lbs of torque through his
Old 06-22-2013, 11:21 AM
Killa SS's Avatar
Driving. Smooth shift to 3rd. Got in it and that was her last pull for third. It just free revved. I checked other gears as I slowed to stop and check **** out under neath. Just lost 3rd
Old 06-22-2013, 11:26 AM
sorry to hear that man, I am taking my car to the dyno on monday. I am trying to get my BRFPS tuned up for a few more whp. Gonna stop at 440 whp. I am trying to keep my car in great daily driving condition and still maintain my WOT power. The car right now is a beast and so much fun to drive. I am not going to lean on her to much harder.
Old 06-22-2013, 05:00 PM
Killa SS's Avatar
Yea it sucks. Im waiting on zzp to put together a f40 conversion kit together before I order my trans. Found one pretty cheap ima pick up and install myself. Save some cash
Old 06-23-2013, 07:46 AM
Whats your plans now ? Theres not any parts available to rebuild unless you have a donor trans. Is it LSD ?
Old 06-23-2013, 10:19 AM
Killa SS's Avatar
Jeff. We talked on the phone a few days ago. Its not lsd. Im just waiting on zzp. I d9nt need my car right now. I have my bike
Old 06-23-2013, 11:24 AM
Ha Ha Ok
Old 06-25-2013, 12:41 PM
pacotaco's Avatar
it should be noted that you CANNOT buy parts for these transmission no matter what version you look up. and btw it is also used in 2003-2004 saab's, and there are v6 saabs running 400+ hp and 450+ torque.
Old 06-25-2013, 04:01 PM
Why would you need parts. You can buy the trans for 300 and up. Theres new ones on carpart for as low as 400
Old 06-25-2013, 04:37 PM
Killa SS's Avatar
We dont want the pre 2007 trans tho do we? Too long of gears right?
Old 06-27-2013, 08:23 PM
pacotaco's Avatar
because pre 2007 transmissions have bad 5th gear syncros. id love to see where your finding these for 300 dollars, the closest to that i have seen is the mu9 v6 transmission. everything on car-part is 650+ the average is around 1200 dollars. the sub 2006 6 speeds are mt2 code btw.
im currently swaping auto to manual with a 2004 f40 transmission and the bad syncro is my biggest fear about using that transmission.
there is not much difference.
Old 06-27-2013, 09:48 PM
I search to find deals plus I deal with yards and warehouses over and over so I get stuff they cant sell cheep
Quick Reply: 2008 Saab F40 info
